milling bits vs. router bits?
dave_the_nerd
Post by dave_the_nerd » Mon Mar 16, 2015 2:31 am
So, since I have a DW660 now, I've been experimenting with a 1/4" 2-flute straight router bit (which I had on hand) instead of purchasing a "proper" endmill.
It's great, from the standpoint of removing a lot of material, but working in oak, I got a bit of scorching, and am wondering if this is something that's just to be expected from router bits, if a "real" endmill would alleviate that, or if I should be cooling/lubricating the endmill somehow when working with hardwood?
I have my eye on this endmill, since I have a couple of 1/8" shank endmills from them and am happy with the performance.
LTEPM
Re: milling bits vs. router bits?
Post by LTEPM » Mon Mar 16, 2015 2:50 am
If you get burning in hardwood typically your spindle speed is too high or feed rate is too slow. (Speaking from using a router)
Post by WillAdams » Mon Mar 16, 2015 2:51 am
While a "real" endmill would probably help, slowing down the r.p.m.s and/or increasing the feed or reducing runout will help more.
Please see: http://projects.shapeoko.com/forum/view ... =30#p26665 for one take on the latter.
Also: http://www.shapeoko.com/wiki/index.php/Endmills esp. http://www.shapeoko.com/wiki/index.php/ ... iple_Flute
mydarndest
Post by mydarndest » Tue Mar 17, 2015 1:51 am
LTEPM wrote:If you get burning in hardwood typically your spindle speed is too high or feed rate is too slow. (Speaking from using a router)
I agree. Too fast motor speed/too slow feed, your going to burn.
Another thing to note is the burning/scorching is caused by the saw dust (powder).
Not always the bit against the wood. You got to get the dust out of the way.
Therefore:
Upcut bits work best for me.
Downcut bits for shallow cuts. If I go to deep .5inch there is too much heat, dust can't get out and it burns/smokes/ruins the bit.
Compression bits - They end up burned up like the downcut bits. I feel like I'm wasting money on these.
Variables are always changing with material and sharpness/dullness of bits.
I am believing I'll be battling this ... forever.
Finding the right feed/speed for materials is a constant research project.
My best cuts are:
Depth of Pass: .05inch to around .0313inch
30 Inches Per minute
This shaves off the material and gets it out of the way for it to be sucked up by my dust shoe/vac.
I dream of the day I can hog out .25 inch depth at 30 inch/min on my SO. :lol:
woodworkerbob
Post by woodworkerbob » Thu Mar 19, 2015 11:07 pm
Slightly off topic, but important for end mills.
I have two precision collets, 1/8 and 1/4". I made the mistake of ordering only 1 nut. For these precision collets, the collets snap/wedge into the nut used to tightening. It's a pain to move that nut back and forth between the collets. Now I have to pay for shipping for just one nut.
Just a little hint.
Bob, Future SO3 owner
SVEMakerSpaces
Woodworker
Post by Woodworker » Fri Mar 20, 2015 12:30 am
Been there and did that also. Trying now to convince myself to just order the 2nd nut and save a lot of time.
