my new horizontal work-holding clamps
lordmundi
Post by lordmundi » Sat May 09, 2015 9:39 pm
Here are some new horizontal work-holding clamps for my ShapeOKO 2 that I designed in Fusion 360 and printed on a Makerbot Replicator 2.
fl0yd
Re: my new horizontal work-holding clamps
Post by fl0yd » Sat May 09, 2015 10:24 pm
lordmundi wrote:Here are some new horizontal work-holding clamps for my ShapeOKO 2 that I designed in Fusion 360 and printed on a Makerbot Replicator 2.
I'm not in a position to watch the video, so would you mind answering what the spacing of your waste board screws is?
Fl0yd
lordmundi
Post by lordmundi » Sun May 10, 2015 1:36 am
Well, mine are 10 cm horizontal and 9 cm vertical. But as I mentioned in the video, the model is parametric so I can easily type in a number and adjust the slot separations.
Also, the design is available here if anyone is interested: http://www.thingiverse.com/thing:818842
Improbable Construct
Post by Improbable Construct » Sun May 10, 2015 2:29 pm
Be careful using horizontal clamps, especially when doing deep cuts. Removing machining can weaken the material and cause the clamp to come loose. Things go very bad from there.
Shapeoko 2 # 3926 not stock
Shapeoko 3 # 0003
Store:
Twitter:
lordmundi
Post by lordmundi » Sun May 10, 2015 2:30 pm
true, but these don't provide any clamping force. they are simply there to be right about against structure to keep it from sliding. I see what you mean though.
