SO3 Machining Aluminum
heathenx
Re: SO3 Machining Aluminum
Post by heathenx » Sun Aug 09, 2015 1:28 am
Oh, you may still want that loc-line. Thats a good idea. I dont want to use air because I dont want debris everywhere but if my router was out in the shop then it wouldnt matter. Until then its vacuuming for me.
TomDChi
Post by TomDChi » Mon Aug 10, 2015 3:09 am
We'll see. I'll be setting up in my basement workshop, but I'd rather not litter the place with aluminum dust. Watching lots of "serious" CNC machining videos on youtube, I may have an unrealistic idea of what chips will be like coming off of this setup (In that they'll be tiny and light off a shapeoko, versus thicker, heavier chips off a Tormach) Though, if they're small and light, it should be easier to get them up with a dust shoe and vac potentially. I'll just have to play with it and see what works!
Fablicator
Post by Fablicator » Sun Sep 13, 2015 5:32 pm
Now that I'm all up and running, I finally got to cut into some aluminum!
Pretty much spent every free moment since wedensday getting my machine calibrated, ,set up with end stops, learning how to set up coordinate systems, and ditching carbide motion in favor of Universal G-Code sender.
Turns out I was right about being conservative! I've been cutting test pockets and am up to 80ipm, .1" overlap, and .063" DOC for a material removal rate of .5in^3/min
https://www.youtube.com/watch?v=AKbOUOItRSE
80IPM is kind of scary, but awesome!
I'm going to push to 100IPM by the end of today, or break an end mill trying.
Post by WillAdams » Sun Sep 13, 2015 6:07 pm
Smokin’!
Added to the wiki as a footnote.
Glad to see someone having success, it’s been a tedious weekend of trying here, w/o much to show but some broken endmills and various notes on the wiki.
Alie
Post by Alie » Sun Sep 13, 2015 10:18 pm
I cut a "grill" into the "protection plate" that covers the electronics of the shapeoko 3 to mount an 80mm fan, i did it no problem without lubricant. My settings:
2 flute 8mm carbide bit
1000mmpm (sorry metric only here)
Stepown 1 mm
Overlap 3 mm
Dewalt set on 5
Fablicator
Post by Fablicator » Sun Sep 13, 2015 10:32 pm
Just ran a 30 min job with the high feeds without any feed related issue... Messed up my work piece prior to starting with a poorly thought out full diameter pass at 100ipm and .063" depth.
On a positive note I stalled the machine and router instead of breaking my 1/4in stub endmill.
Part is just a test piece. Pockets are 1/4in deep and the 'core' is .4" tall.
On another note, I really need to make a dust shoe. i was getting hit by unpleasantly hot chips 4ft away from the machine.
I've determined that cuts can be much more aggressive in the X axis than the Y. The steel plate the DW611 is attached to is vibrating like crazy compared to the rest of the machine.
TomDChi
Post by TomDChi » Mon Sep 14, 2015 4:00 am
Fablicator - very cool!
Is that an uncoated end mill or coated? I've been using the Lakeshore ZrN and it seems good, but uncoated is cheaper if it works well.
For the actual pockets on the roughing, what is the IPM and how deep are you going per pass?
I think the plate that the router mount bolts to needs some stiffening. The v wheels are all up a bit from the mount holes, so when force is applied way out at the end mill, it can flex that plate. Stiffeners to make the plate "deeper" to resist bending would be nice.
Fablicator
Post by Fablicator » Mon Sep 14, 2015 4:20 am
TomDChi wrote:Fablicator - very cool!
Uncoated end mill. I assumed I'd break it doing something stupid far before it ever wore out.
For the roughing, 80IPM, .063" deep, .1" stepover.
I'm already contemplating machining a new plate from 3/4in thick aluminum I have laying around. Doesn't seem like the extra weight would hurt, and the stock springs are pretty useless as-is. My only real concern is how to make the eccentric nuts work on such a thick plate.
~Andrew
Okinawanwinds
Post by Okinawanwinds » Mon Sep 14, 2015 12:10 pm
congrats, and tell me how do you protect from flying broken end-mill bit?
AnonymousPerson
Post by AnonymousPerson » Mon Sep 14, 2015 12:51 pm
Fablicator wrote:I'm already contemplating machining a new plate from 3/4in thick aluminum I have laying around. Doesn't seem like the extra weight would hurt, and the stock springs are pretty useless as-is. My only real concern is how to make the eccentric nuts work on such a thick plate.
Does this help?
http://us.misumi-ec.com/vona2/result/?K ... ntric+Bolt
