Depth Rings / Distance Rings
TDA
Re: Depth Rings / Distance Rings
Post by TDA » Tue Jan 12, 2016 10:59 pm
Be VERY careful with those larger metal depth collars. All the ones I've seen are made for drills and much lower RPM than what most routers slowest speed is. They could cause bearing damage or be a safety concern if they are unbalanced enough.
John Torrez
Think & Tinker / PreciseBits
heathenx
Post by heathenx » Tue Jan 12, 2016 11:03 pm
TomDChi wrote:So once you have some loose rings, what is a reliable way to set them on the mills to a precise length/depth for repeatable tool changes?
I use a depth gauge. Put collar on end mill, place it upside down in a plate with either a 1/8 or 1/4 hole. Zero the gauge on the plate surface and then touch off on the top of the end mill.
jbc
Post by jbc » Wed Jan 13, 2016 1:16 am
TDA wrote:Be VERY careful with those larger metal depth collars. All the ones I've seen are made for drills and much lower RPM than what most routers slowest speed is. They could cause bearing damage or be a safety concern if they are unbalanced enough.
I had heard that and with your comment I will continue the search for the plastic fit on rings.
jbc
jbc
VCarvePro 8
3D Printing prototypes
Sketchup
http://www.CaffeineMachine.com
samc99us
Post by samc99us » Wed Jan 13, 2016 9:18 pm
Let me know if you find any for the 1/4" size! Think and tinker sell them for the 1/8"...
