Trying To Get The V Grove Groovy
johnelle
Post by johnelle » Sat Jul 29, 2017 7:19 pm
I am still fairly new to this but I am having a lot of trouble with my current project which is very very simple--my daughter's company logo on coasters.
I cannot for the life of me get the lettering crisp. I have tried varying the speed from Dremel 2 to 3.5 (the recommended). Tried Feeds from 25 to 75. Tried pine and some fairly thin popular. I am using a brand new Nomad 1/2 V60 bit. I am no blaming the font and/or the size. I just cannot get it crisp.
Please share some accumulated wisdom with me.
Shown is a piece of poplar. Multiple passes at different speeds. Still ragged.
V60 on 1/4 inch poplar. Multiple passes at different speeds
Schruminator
Re: Trying To Get The V Grove Groovy
Post by Schruminator » Mon Jul 31, 2017 5:42 pm
I tried a 90 degree V bit of a similar style to the Nomad one you're using and got terrible results as well. I now exclusively use V bits of this style here:
eBay Listing Link
I use primarily 1/4" endmills in my Dewalt palm router, but the results with these sharp tipped V bits (and they are needle sharp!) are leagues better than I got with the Nomad-style bit I was using. I've repurposed that Nomad-style bit for chamfering holes I drill. It will never be used to v-carve again. If that ebay link is dead, search for "60 degree carbide bit" and look for one without the bulbous head similar to this photo here.
Schruminator
Post by Schruminator » Mon Jul 31, 2017 5:46 pm
I should mention that I have not used the specific v-bit I linked to, all of mine are 1/4" diameter-- but those three or four 1/4" ones are basically identical in design to the one I linked to and from the same seller. Most of my v carving has been in poplar, and generally the endmills have produced excellent results.
Post by WillAdams » Tue Aug 01, 2017 12:44 pm
Another consideration here is how fine/coarse-grained the wood is.
My suggestion would be to do a test cut in MDF (which essentially has no grain), then work your way through wood species until you find one at the right price and cut quality.
