g540 enclosures
Get help with the Geckodrive motor controller
lioramsalem
g540 enclosures
Post by lioramsalem » Fri Feb 13, 2015 5:12 pm
Hi,
I'm right before buying a g540 for my Shapeoko2 (and future mill conversion)
Here are the available enclosures I found:
1. Automation technology g540 enclosure (89$) http://www.automationtechnologiesinc.co ... wer-outlet
Comes pre-cut and with power socket/switch/estop.
2. Homann Design: http://www.homanndesigns.com/store/inde ... ucts_id=93
3. Hammond 1402KV (~60$) http://www.hammondmfg.com/dwg10.htm
User build log/pictures from cnczone: http://www.cnczone.com/forums/gecko-dri ... forum.html
If you have other alternatives update the thread...
LA
ShapeOko 2 #5840 w/ NEMA23, ACME Z axe belt upgrade, limit switches, spindle speed control, 400w brushless spindle, 9mm belts, aluminum bed, eShapeoko X carriage and belts system
Build log: http://www.shapeoko.com/forum/viewtopic.php?f=5&t=3650
danimal
Re: g540 enclosures
Post by danimal » Sun May 24, 2015 7:13 pm
I bought the case linked below off of Amazon ($22). I am very impressed with the construction and quality of the box, it is 1/8 thick at least, with molded in inserts that the cover screws thread into. I used the cover that was already installed on the power supply, and cut it to fit into the enclosure for the fan mount and the ventilation port on the sides. I used the meanwell 48V power supply for my build. It was pretty quick and easy, especially if you already have a cnc to cut the profiles on the lid.
http://www.amazon.com/gp/product/B005T7 ... UTF8&psc=1
Shapeoko # 1458
