Shapeoko 3 - Assembly Instructions (preliminary)
Current version instructions are available at:
- http://carbide3d.com/shapeoko/assembly/
- http://carbide3d.com/shapeoko/assembly/xl-assembly/
- http://carbide3d.com/shapeoko/assembly/xxl-assembly/
Attached are the latest instructions provided for the assembly of the launch edition of the Shapeoko 3.
DOWNLOAD HERE --> http://carbide3d.com/files/so3manual.pdf
Previous versions:
- http://bit.ly/1PQoKDi
- http://bit.ly/1Fh1gXF — checked 25 September 9:07 A.M
- http://bit.ly/1iAfiJQ see http://www.shapeoko.com/forum/viewtopic ... 862#p53862
- http://bit.ly/1HRWBcY
- http://bit.ly/1VMlUTr)
Previous versions:
Re: Shapeoko 3 - Assembly Instructions (preliminary)
Thanks Edward, glad to be able to review it while waiting for my tracking info. It looks like you are missing page 19. Page 18 shows wire routing then it skips to page 20 packing list (cont.).
Edward; I'm nit picking here. On page 2 of 22. Paragraph "Where to get help if you need it?", "#2 Wiki" The link to the wiki does not work because it carries over the trailing "]" square brace. FYI
P.S. I should add this was with Adobe Reader on a Win 7 computer and Chrome browser.
Joe C.
Joe C.
Looking at the .pdf, that seems to be 'cause it's not enabled as a link w/in the .pdf --- your Acrobat is auto-constructing the link wrongly --- if we make that as a link w/in the program which made the .pdf that should fix it.
To pass the time I've been reading and reading the instructions and I too am missing page 19 from the instructions provided by the link at top here.
Any update to the file with page 19.
Shapeoko 3 #304
I believe pg. 19 should be the beginning of the B.O.M. Please see if the copy on the wiki will serve:
http://www.shapeoko.com/wiki/index.php/ ... 8B.O.M..29
Shapeoko 3 startup
im new to all of that has to do with software and forums. So i need HELP. where do I go for help with going from software (V Carve Pro Desktop) to my Shapeoko 3 router?
Click on Board Index | Software - CAD, CAM, Workflow Help:
http://www.shapeoko.com/forum/viewforum.php?f=6
I think Page 19 might be on how to mount the belts for x and y axis, as there are no instructions for this process. Also no instructions or screws to mount the fan.
XYZprinting Da Vinci 1.0A with repetier 0.92 firmware.
Shapeoko 3 #253
Shapeoko 3 #253
motor wiring
I think they were quite vague as to the placement of the motors concering the wiring lenghts and where does the short and the long wires go, and what is the tube of liquid for?
I presume it is a thread locking liquid and used for the allen set screws.
