I wanted the single piece waste board with the T-nuts when I started initial assembly. Don't want to assemble twice. What can I say, I'm just that lazy.
Thanks,
Bob
I will try to get something released today. You want a dimensional layout of the area to place another piece of 1/2" or 3/4" MDF (or other material)? Correct?woodworkerbob wrote:Wasteboard
Have a dimensional drawing for a one piece wasteboard been released?
I'm on sort of a deadline. I have access to a large CNC machine (plans to cut wasteboard there) but only until mid May, when school ends. I could measure the two half boards, but I would prefer a better source (than me) for the correct dimensions.
Thanks,
Bob
I actually considered that arrangement while I was assembling my machine, but stopped 'cause I wanted to try the stock configuration first --- it seemed to me that one could put the bolt in from the top (it'd have to be full-thread, not a problem at these lengths), pulling the PEM nut tight, then tighten _only_ the nut from the bottom while holding the bolt from the top which seemed to me to be a royal pain.veng1 wrote:...look at the waste board and see if it could be mounted on the bottom side? Then the sacrificial waste board could be on the top without any loss of height by stacking.
Note that this is pulling the PEM nuts in the wrong direction and it may require hex nuts on the end of the screws to avoid pulling the PEMs out.
Really nice drawing. The Y dimension of the 2 horizontal holes right in the middle of the board should be about 290 mm? My guess of the locations would be (340.87,290) and (380.87,290). I couldn't find position information.edwardrford wrote: I will try to get something released today.
edit: download file here -->http://bit.ly/1Fh5lJ5
