3D model of Shapeoko 3
AnonymousPerson
Re: 3D model of Shapeoko 3
Post by AnonymousPerson » Thu Sep 10, 2015 4:01 pm
Milled out that .stl (above) from a sheet of plaster. The holes are exactly the right size, and in the exact correct spot. The only thing that could have been better, was the tabs could have been 1mm longer on the outside each. Photo's below, showing the plaster cut out against the actual plate, with the M5 and M6 bolts put through.
S3 Z-axis plate v3 - 1.jpg (184.71 KiB) Viewed 2575 times
S3 Z-axis plate v3 - 2.jpg (169.11 KiB) Viewed 2575 times
S3 Z-axis plate v3 - 3.jpg (153.93 KiB) Viewed 2575 times
Shapeoko 3 #516
AnonymousPerson
Post by AnonymousPerson » Thu Sep 10, 2015 4:03 pm
Here's an updated STL, with the corrected tabs:
Shapeoko 3 Z-axis plate (3rd version).stl
(164.93 KiB) Downloaded 883 times
This version is accurate, and good to use. :)
If you need some other file format for it, you can try grabbing it from the Fusion 360 site here:
http://a360.co/1ENmYlC
License wise, it's Creative Commons BY-SA. You're fine to use it commercially.
Last edited by AnonymousPerson on Thu Sep 24, 2015 7:42 pm, edited 1 time in total.
Shapeoko 3 #516
jayftee
Post by jayftee » Sat Sep 12, 2015 2:23 pm
Nice work.
You made a model for fun or, you plan on making a mod for something, like endstop or what not?
Now, what I am missing to begin work on the 3D model, would be the Y plates... :P
AnonymousPerson
Post by AnonymousPerson » Sat Sep 12, 2015 2:32 pm
I'm mucking around with designing an integrated end plate + spindle mount (no idea if it will turn out ok), so I needed something to work with. :)
It also gave me an opportunity for practising with Fusion 360, which I'm new to. ;)
I might be able to get the Y-plate done... but it's a slow/non-fun process, and I don't have a real need for the end result personally (yet). So, it won't be this week. :evil:
Shapeoko 3 #516
Post by WillAdams » Sat Sep 12, 2015 3:16 pm
How are spindle mounts attached on commercial machines?
If memory serves, we’ve discussed alternate and quick change mounts in the past. I’ve been considering using a circular part in the ShapeOko 3’s spindle mount, but not really liking any of the design concepts I’ve come up w/ thus far. Also not wild about metal fatigue on it from (I either need to break down and get a DWP611 or make a new mount or a better adapter).
AnonymousPerson
Post by AnonymousPerson » Sat Sep 12, 2015 3:48 pm
I'm actually kind of avoiding looking at the commercial machines much. Don't really want to have any patent issues with well funded companies. :shock:
Experimenting with ceramics/cements at the moment, which could allow for some interesting designs. Might not have the durability needed, but unsure.
Will be finding out in a few days. ;)
Shapeoko 3 #516
Fablicator
Post by Fablicator » Mon Sep 14, 2015 4:23 pm
AnonymousPerson wrote:I'm mucking around with designing an integrated end plate + spindle mount (no idea if it will turn out ok), so I needed something to work with. :)
Whenever I need to "copy" a plate, I scan it on a flatbed scanner next to a ruler. Scale the picture appropriately in CAD and you can pretty much trace the whole thing to within .005"
AnonymousPerson
Post by AnonymousPerson » Mon Sep 14, 2015 4:52 pm
Gah. I have a scanner, but didn't think of that. Thanks for the concept. :)
Shapeoko 3 #516
BuildMaster
Post by BuildMaster » Fri Sep 18, 2015 5:29 pm
Working on pieces in Fusion 360 as well, here is the 600mm extrusion, 99% accurate. Inside might not be perfect but outside and hole placement should be good.
Modified G-Max 3D Printer
Shapeoko 3 - Soon to be Frankenoko 3.1
Fusion 360 - AuotoCAD
To many toys! To little time!
AnonymousPerson
Post by AnonymousPerson » Fri Sep 18, 2015 6:36 pm
Cool. Want me to add you to my project in Fusion 360, so we have all the parts in one place?
Shapeoko 3 #516
