3D model of Shapeoko 3
Re: 3D model of Shapeoko 3
Sorry this has taken so long - I'll get these all bundled up soon.
Until then, here's the spindle mount plate and the Y carriage and the extrusion profile.
- Attachments
- PS3000.pdf
- (123.91 KiB) Downloaded 2682 times
- PS3004.pdf
- (117.66 KiB) Downloaded 1599 times
- PS3001.pdf
- (141.08 KiB) Downloaded 3259 times
Here are the rest of the files, in PDF format, available as a zip packaged.
https://www.dropbox.com/s/271fcka1wmynt ... 1.zip?dl=1
Part S3000 - Extrusion as per the exact drawing specifications:
Fusion 360 Shared link: http://a360.co/1Kt3U8g
Jeff
Jeff
- Attachments
- S3000 - Extrusion v6.zip
- STL and STEP
- (146.24 KiB) Downloaded 1065 times
Part S3001 - Y Axis Mount Plate as per the exact drawing specifications:
Fusion 360 Shared link: http://a360.co/1Kt3O0w
Jeff
Jeff
- Attachments
- S3001 - Y Axis Mount Plate v6.zip
- STL and STEP
- (52.88 KiB) Downloaded 889 times
Jay, what license are you releasing those models under? Something that allows commercial usage?
I'm kinda thinking CC-SA might be optimal for encouraging people to contribute back any changes... but open hardware licensing isn't a topic I understand in huge depth yet. Might need to bump it up the priority list of things to investigate.
Shapeoko 3 #516
Those are free as in free beer.
I simply wish there would be a github for the shapeoko 3, with a master branch being the official stuff from Carbide 3D and branches made by contibutors.
However, my 3D models cannot overwride the copyright of Carbide 3D's work. I simply made 3D models based on their released documentation and thus, my work should follow the same model.
In other words, they released 2D pdf files of their components, I just translated them in 3D.
Jeff
Jeff
No worries. Looks like I'll need to make my own models then, as I need them.
Shapeoko 3 #516
Under the CC BY-NC which is the copyright used in Carbide's PFS, it means:AnonymousPerson wrote:No worries. Looks like I'll need to make my own models then, as I need them.
You are free to:
- Share — copy and redistribute the material in any medium or format
Adapt — remix, transform, and build upon the material
The licensor cannot revoke these freedoms as long as you follow the license terms.
- Attribution — You must give appropriate credit, provide a link to the license, and indicate if changes were made. You may do so in any reasonable
manner, but not in any way that suggests the licensor endorses you or your use.
NonCommercial — You may not use the material for commercial purposes.
No additional restrictions — You may not apply legal terms or technological measures that legally restrict others from doing anything the license permits.
So, in the end, you may use the 3D models any which way you like by applying the rules above.
Jeff
Part S3003 - X Axis Mount Plate as per the exact drawing specifications:
Fusion 360 Shared link: http://a360.co/1V3i7Pi
Jeff
Jeff
- Attachments
- S3003 - X Axis Mount Plate v4.zip
- STL and STEP
- (75.38 KiB) Downloaded 1067 times
