I downloaded "Easel local 0.2.1", connected the USB cable to my PC and clickt on "CARVE" in my Easel program and nothing is happening!
Are there any sketches or any instruction for all the steps to follow after the assembly is done?
Once you’ve got that and the driver which it installs installed you should be able to use your choice of Communication / Control software (Easel should then be able to connect).The default control program for the Shapeoko 3, any G-code sender which will communicate w/ Grbl will work.[4] Written using QT frameworks. Available for Windows 7 and later, Mac OS X 10.7 and later. New beta supports Shapeoko[5]
Type L at the main screen for a log window, M for an "MDI" window which allows manually interacting w/ Grbl.[6] If you have selected 1/8 micro-stepping, send $100=40.0 and $101=40.0 and $102=40.0 to set the steps for micro-stepping for X-, Y- and Z-axes respectively.
