Nema 23 stepper motor
franazzo
Post by franazzo » Fri May 22, 2015 10:03 pm
Are the motors for shapeoko3, the NEMA23, 3 Volts ? I have to know asp! Thanks
Re: Nema 23 stepper motor
Post by cvoinescu » Fri May 22, 2015 10:10 pm
AFAIK, they are Wantai Motor 57BYGH218, and you can find the specs here: http://www.wantmotor.com/ProductsView.a ... =75&sid=80
There was a photo with a legible label posted on the forum, but I can't find it. The '218 matches the 2 A spec and the apparent 51 mm length, so it's very likely the right one.
Edit: found it: http://www.shapeoko.com/forum/viewtopic ... 587#p47583 -- and yes, it's the 57BYGH218 (the -1 suffix refers to the custom wiring and connector and does not affect the other motor specs).
franazzo
Post by franazzo » Fri May 22, 2015 11:07 pm
cvoinescu wrote:AFAIK, they are Wantai Motor 57BYGH218, and you can find the specs here: http://www.wantmotor.com/ProductsView.a ... =75&sid=80
Sorry for the silly question!!
Our motors with shapeoko 3 are 2.6V, the ones I can find on line are 3V. Can I use the 3V instead the 2.6V?
The specs are:
Step Angle (degrees) : 1.8
4-Phase
Rated Voltage: 3V
Rated Current: 2A/Phase
1/4" Diameter Drive Shaft
Holding Torque: 90N-cm (125 oz-in)
NEMA 23 form factor
Thanks again,
from a very disappointed shapeoko3 owner!!
Post by cvoinescu » Sat May 23, 2015 12:32 am
Those motors will work fine. The voltage rating does not matter much, just the current rating.
franazzo
Post by franazzo » Sat May 23, 2015 2:42 am
cvoinescu wrote:Those motors will work fine. The voltage rating does not matter much, just the current rating.
Thank you again very much, and I wish some people would respond in that timely matter like you do!!!
I think you and Will spend some incredible amount of time in here for us beginner.
Post by cvoinescu » Sat May 23, 2015 10:54 pm
You're welcome.
franazzo wrote:I think you and Will spend some incredible amount of time in here for us beginner.
Don't know about Will, but my wife agrees that I spend way too much time here. :)
franazzo
Post by franazzo » Sun May 24, 2015 9:16 pm
cvoinescu wrote:You're welcome.
Hi cvoinescu, I am back!
I have to replace one motor, my question is, is it smart to replace only one,( different brand) or is it saver to replace all fore?
I found a place here in Canada with the 3A motors for $25.- instead to wait for an answer from carbide.( it is only 3weeks :twisted: )
https://youtu.be/RaGtvVr-fs4
Post by WillAdams » Sun May 24, 2015 9:20 pm
Replacing one should be fine. The SO2 would often be configured to have NEMA23 on X- and Y-axes, w/ a NEMA17 on the Z.
Replace either the X- or the Z- — I suspect it’s important for the Y-axis motors to match, the wiring length needs to so as to match resistance.
Post by cvoinescu » Sun May 24, 2015 9:41 pm
3 A is too much, you need a 2 A motor. I mean, a 3 A motor will work, but you won't get the rated torque, because the Carbide Motion board will only supply 2 A.
There's no reason to replace the good motors. Even on Y, it's okay to use different motors.
