Edward will sent the new pulleys as soon as he get them from the provider it's what he told me. Email them and they will send you one as soon as they are available
ZAxis Assembly Interference
Re: ZAxis Assembly Interference
Adam
Shapeoko 3 w/DPW 611 #243
WIN7 64bit - Trying to figure it out a Workflow
After finding this picture, I'm no longer scratching my head. Thanks!!WillAdams wrote:Maybe this photo will help? Took apart my spindle carriage:
Nut on one side, the V-wheel is sandwiched between washers.
You show the wheels with eccentrics taking 2 washers.. The wheels on the other side take 2, too?
Correct. They need to be symmetrical so as to keep the carriage even.Dave Durant wrote:You show the wheels with eccentrics taking 2 washers.. The wheels on the other side take 2, too?
I'm too slow.. I was just coming back to edit out that question - I put 2 washers on each and it's smoooooth now..
But, while I'm here, is there any reason to not flip the bolt on the lower part of the spring? The ends that attach to the Z plate ears. It seems like if the nut was in the middle (towards the X plate) instead of the head, it would be far easier to install & tighten. The way it is in the drawing makes it difficult to put the hex wrench on.
Swapping that bolt around seems like a good idea to me (or use a hex head bolt there). It’s probably oriented as it is for symmetry. Might want to add a washer.
