Official SO3 Hello World
Re: Official SO3 Hello World
Excellent!
I see there's a newer, sexier Shapeoko in Hartford county!
Shapeoko #1,123
I like how the powder coating came out on the parts I did. Looks cleaner and more professionalHans wrote:I see there's a newer, sexier Shapeoko in Hartford county!
Maker
Mendel90 3d printer
SO3 Batch 1 #?.
Transmission Linemen
Mendel90 3d printer
SO3 Batch 1 #?.
Jem-tech - I think you need to change your microstep settings on your machine. The helloworld appears to be 1/2 the size it should be?
Change the dip switches from 1/8 to 1/4 on your X and Y1 and Y2 switches.
Otherwise - LOOKS GREAT!
edwardrford wrote:Jem-tech - I think you need to change your microstep settings on your machine. The helloworld appears to be 1/2 the size it should be?
Change the dip switches from 1/8 to 1/4 on your X and Y1 and Y2 switches. Should the Z be on 1/8 or 1/4?????
Mine is even smaller!!!! Should I change the dip switches also???
- Attachments
- FullSizeRender.jpg (50.84 KiB) Viewed 1447 times
I must be doing something wrong... my Hello world doesnt want to work. When I put the sharpie and set it like following the instructions from the Carbide3D site, after I set to Zero all and load the project the Z axis goes all thew way up hitting the stoppers then goes all the way down hitting the sharpie to the paper and dis-aligning the sharpie. it then looks like it runs the program but way higher without even touching maybe 3" higher.
Help! I want to say Hello too!
Adam
Adam
Adam
Shapeoko 3 w/DPW 611 #243
WIN7 64bit - Trying to figure it out a Workflow
Adam
Hi Adam -
Go back to the KB article and re-download the file: http://docs.carbide3d.com/article/37-sh ... ello-world
I just updated the g-code to define units (G21 = millimeters) instead of assuming your machine was in mm mode! That was my mistake, should be fixed now.
Also - after watching your video - make sure your DIP switches are all set to 1/4 (X,Y1,Y2,Z).
Edward,
thanks! you mean flipped to the top position? right now they are all in the bottom position.
Adam
Adam
Adam
Put them so they match this photo
