Page 5 of 5
Re: Official SO3 Hello World
Posted: Fri Jul 31, 2015 6:57 pm
by rodcar125
WillAdams wrote:You can edit the G-code in the hello world file to change the F parameters to slow things down.
You might be able to change the max. machine speed by editing an option in Grbl — maybe slow acceleration to the point the machine can’t get up to speed?
Easiest just to add some more rubber bands until the pen is held securely
The hello world file (box_logo.tap) calls a feed rate of 5080 but the x, y and z max rate from grbl settings are 5000mmpm, so, this would be the same as running in rapid mode all the file?
Could someone post the grbl settings for the S3 please?
Good day!
Posted: Fri Jul 31, 2015 7:25 pm
by FabricatorCraig
rodcar125 wrote:Could someone post the grbl settings for the S3 please?
You can find this in the FAQ on the Carbide 3D site:
http://docs.carbide3d.com/article/38-sh ... l-settings
Posted: Thu Aug 06, 2015 4:37 pm
by rafevaughn
First post might as well be a successful HelloWorld right?
This is my first CNC, pretty damn excited to start exploring what it is capable of!
Posted: Thu Aug 06, 2015 9:01 pm
by CastIrony
rafevaughn wrote:First post might as well be a successful HelloWorld right?
I don't know exactly how big mine was, but that looks small. Are your microstepping switches set to 1/4?
Posted: Tue Aug 11, 2015 6:43 pm
by rafevaughn
CastIrony wrote:rafevaughn wrote:First post might as well be a successful HelloWorld right?
You are correct, we had the switches set incorrectly out of the box. Post the drawing we set out to do some test cutting/carving, once done we measured it and discovered the issue and corrected it. I see you are located in Portland as well, good to know there is someone else local with a machine!
Posted: Sat Oct 24, 2015 9:20 pm
by TMcG
Hi,
First Hello World print, bit wonky, could this all be due to the Sharpie and/or table shake ? Probably not right ?
Appreciate the input
- 2015-10-24 17.16.11.jpg (113.17 KiB) Viewed 1536 times
Posted: Sat Oct 24, 2015 9:35 pm
by AnonymousPerson
It kind of looks like it missed a few steps when going horizontally (X direction) at one point. Are any of your belts really loose?
Posted: Sat Oct 24, 2015 9:52 pm
by cvoinescu
It looks like something slipped. You could have missed steps, but it's more likely to be a loose belt, a loose set screw in a belt pulley, a badly attached Sharpie, or even the paper having moved around.
Posted: Sun Oct 25, 2015 12:06 am
by TMcG
Hmm, no, the belts are all guitar string tight, I think it might be shaky table & bad sharpie attachment (maybe)
I'll move to a different setup where she's a bit more pinned down and try again.
thanks
Posted: Mon Oct 26, 2015 6:58 pm
by jbc
I ran my 'Hello World' with the Shapeoko drawn by a sharpie.
It turned out nice ..but backwards, like looking in a mirror.
I switched the 'Y' motor locations and now works as intended.
The right side of the board needed to control the stepper on the left side. Good thing the wires had plenty of length.
This machine looks great. Good job guys. Now to cut something
jbc
