Easel changed z axis movement rate with Shapeoko3
meyercnc
Post by meyercnc » Wed Jul 08, 2015 3:42 am
CNC noob alert. I was attempting to see if I could use Easel with Shapeoko 3 and the z axis now moves way too fast/far even using the carbide motion move cutter utility. I've tried turning off, unplugging everything, to try to get the z axis to return to normal stepping, but to no avail so far. X and Y axis movement is fine, its just the Z axis. Any ideas on how to get Z axis movement back to normal?
FabricatorCraig
Re: Easel changed z axis movement rate with Shapeoko3
Post by FabricatorCraig » Wed Jul 08, 2015 10:18 am
@meyercnc
I would have a look at this Knowledge Base article on validating your controller configuration. It provides details on how to check if any of the defaults have been modified:
http://docs.carbide3d.com/article/38-sh ... l-settings
-----------------Craig The Fabricator-----------------
SO1 - (1) Red Powder-Coat & (1) Non-Painted Steel
SO2 - (2) w/ lots of I.C. & other upgrades
SO3 - Serial #447
Post by cvoinescu » Wed Jul 08, 2015 10:40 am
Easel is too smart by half. It is designed for the Shapeoko 2, but that's no excuse for changing your settings without asking. Even if you have a Shapeoko 2, it could well be a non-standard configuration -- or maybe you spent the time to calibrate it accurately, and it just flushes your work down the drain.
