S3 keeps over running the work space
Frank741
Post by Frank741 » Sun Jul 12, 2015 8:36 pm
I tried to air and print(with pen) the hello world gcode file. It seems like the jobs try to print 4X the size of what I expect it should and the machine hits the limit of the x axis.
I have tried to reset the origin
Grbl 0.9g
$0=10 (step pulse, usec)
$1=25 (step idle delay, msec)
$3=6 (dir port invert mask:00000110)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$11=0.020 (junction deviation, mm)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$14=1 (auto start, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$24=25.000 (homing feed, mm/min)
$25=500.000 (homing seek, mm/min)
$26=250 (homing debounce, msec)
$27=1.000 (homing pull-off, mm)
$100=250.000 (x, step/mm)
$101=250.000 (y, step/mm)
$102=250.000 (z, step/mm)
$110=500.000 (x max rate, mm/min)
$111=500.000 (y max rate, mm/min)
$112=500.000 (z max rate, mm/min)
$120=10.000 (x accel, mm/sec^2)
$121=10.000 (y accel, mm/sec^2)
$122=10.000 (z accel, mm/sec^2)
$130=200.000 (x max travel, mm)
$131=200.000 (y max travel, mm)
132=200.000 (z max travel, mm)
any tips or troubleshooting suggestions
dws
Re: S3 keeps over running the work space
Post by dws » Sun Jul 12, 2015 10:04 pm
It appears that many of the default settings are wrong. Try setting them to the correct defaults and see if that fixes the problem. http://docs.carbide3d.com/article/38-sh ... l-settings
Frank741
Post by Frank741 » Mon Jul 13, 2015 12:27 am
that did it
thank you
FabricatorCraig
Post by FabricatorCraig » Mon Jul 13, 2015 5:57 pm
@Frank
Did you, by any chance, try using Inventable's Easel software on your SO3? People have seen problems with Easel overwriting the default SO3 settings with values conducive to SO2's and/or X-Carves.
SO3 - Serial #447
