V Wheel Woes
dws
Re: V Wheel Woes
Post by dws » Thu Oct 15, 2015 5:01 pm
I had the two bottom V Wheels break on the X-Axis. It was the second run on cutting 1/2" plywood. The first run worked fine; however, using the same file on the second piece of plywood, the Z-Axis dropped much more than it was supposed to, damaged the plywood, and broke the V-wheels. I am not sure what caused this, or how to fix.
I ordered some V Wheels from Inventables. They fit fine; however, they are narrower and are probably more susceptible to breakage.
Re: V Wheel Woes
Post by WillAdams » Thu Oct 15, 2015 5:09 pm
I had problems w/ my Z-axis dropping too low until I used a small prybar to help tension the Z-axis belt.
TomO
Re: V Wheel Woes
Post by TomO » Thu Oct 15, 2015 10:26 pm
dws wrote:I ordered some V Wheels from Inventables. They fit fine; however, they are narrower and are probably more susceptible to breakage.
Anyone know if the other vendors offer exact replacements?
AnonymousPerson
Re: V Wheel Woes
Post by AnonymousPerson » Sat Oct 17, 2015 6:03 pm
Just came across this on eBay:
http://www.ebay.co.uk/itm/291473082668
Looks like an exact replacement. :)
Note - I don't have any relationship to the vendor, never used them before, etc.
Re: V Wheel Woes
Post by cvoinescu » Mon Oct 19, 2015 4:58 pm
How's that different from the V-wheel from Inventables?
AnonymousPerson
Re: V Wheel Woes
Post by AnonymousPerson » Mon Oct 19, 2015 6:38 pm
Not sure. It sounds like the ones from Inventables aren't an exact replacement. Was kind of thinking these ones might be.
Re: V Wheel Woes
Post by cvoinescu » Mon Oct 19, 2015 7:24 pm
Those V-wheels are identical to the ones I have, and mine are the same as the ones from Inventables. They match this technical drawing (PDF). Not sure what the exact dimensions are for the ones on the Shapeoko 3, but the few pictures I saw (including the one in this post) looked the same too.
AnonymousPerson
Re: V Wheel Woes
Post by AnonymousPerson » Mon Oct 19, 2015 8:06 pm
Oh well. Sorry then. :(
Re: V Wheel Woes
Post by cvoinescu » Mon Oct 19, 2015 8:19 pm
If the Shapeoko 3 V-wheels are indeed wider (and I believe that), then nobody has an exact replacement...
dws
Re: V Wheel Woes
Post by dws » Mon Oct 19, 2015 9:06 pm
I apologize for my previous post. I said that the V Wheels from Inventables are narrower than the Shapeoko 3; however, after measuring both, they are the same. My eyesight is not as good as it used to be. When I installed the V Wheels from Inventables, they appeared to me to be narrower.
