Lip on the bottom 1.5-3mm of parts
Chembro
Post by Chembro » Wed Dec 02, 2015 12:13 am
I have a lip that's coming up on the button of my parts.
I'm not sure if it's belt stretch/slip on the X axis that's causing it but I've made flats on my motor shafts and my set screws are as tight as I could get them without stripping something.
I'm thinking that maybe my bit isn't sharp enough and is causing extra force on the X axis since it's running one belt instead of two like the y axis.
The A Run has the largest lip measuring approx. ~1mm, and is unfit for sale.
Run B had a very small lip approx. ~.25mm and measures close enough to the CAD drawing to mail them to the consumer which is why they're missing.
I highlighted the lip with orange/silver and put an axis for reference.
Re: Lip on the bottom 1.5-3mm of parts
Post by WillAdams » Wed Dec 02, 2015 1:35 am
Check the Z-axis V-wheels, consider climb vs. Conventional milling / path direction?
Chembro
Post by Chembro » Wed Dec 02, 2015 1:58 am
I'll double check the v-wheels next. I've included a picture of my tool settings for cutting phenolic.
Fablicator
Post by Fablicator » Wed Dec 02, 2015 2:30 am
Check your endmill!
I had parts turn out like this and it turned out I chipped the tips off my end mill. I only saw the ridge on the deepest pass since the higher up section of the endmill was still OK.
Chembro
Post by Chembro » Wed Dec 02, 2015 2:18 pm
If it were the cutter tip you would see this lip all the way around the part.
This issues is more of a shadow on one side. Something is skipping steps.
My z-axis v-wheels are solid, unless another one cracked and when it gets close to the wasteboard it falls into a rut on the wheel. There is flex in the z axis plate though, which shouldn't be a problem if the endmill is cutting and not pushing.
Post by WillAdams » Wed Dec 02, 2015 2:31 pm
Yeah Garolite is tough stuff. I wonder if reinforcing the Z-axis spindle carriage plate isn't going to be the biggest bang for the buck upgrade for the SO3. Still debating what I want to do for mine.
Another consideration --- are the top / bottom layers tougher than the inner? Maybe rejigger the paths to take that into account?
Chembro
Post by Chembro » Wed Dec 02, 2015 3:30 pm
I'll just slow down the machine to 40IPM on the next run and see if that helps at all. If so I know where my issue is. This is actually CE Phenolic which is a cotton weave epoxy sheet and is much softer than Garolite. Garolite is usually a glass weave and is a pain to machine and will eat through carbide like butter.
Ask me how I know :lol:
If I can tinker and find a solution I'll post it here as a reference if anyone else is having the issue.
Will, I'm not sure how the z axis can be supported, I was thinking of adding an extra set of v-wheels but it wont work once the machine plunges and they will derail. Maybe Edwards Z axis mod that covers the springs added a little rigidity to the set up?
I'm not too familiar with g-code to actually code by hand or modify it. I'm using MeshCam and adding toolpaths together is about my limit. :?
Fablicator
Post by Fablicator » Wed Dec 02, 2015 4:26 pm
Chembro wrote:If it were the cutter tip you would see this lip all the way around the part.
Couldn't tell it wasn't all around.
Are you 100% sure of your work holding?
Chembro
Post by Chembro » Wed Dec 02, 2015 6:29 pm
I'm bolting things to the the wasteboard with 1/4in -20 hardware with 6 prong t-nuts.
Doesn't mean it can't shift though.
"Shrugs"
I'll figure it out. Eventually.
Chembro
Post by Chembro » Wed Jan 20, 2016 9:45 pm
So after running the machine again for the first time since I made this run. I did a "test" by not changing anything from the last run and I didn't get the lip this time.
My conclusion is that I was pushing the machine too hard. Instead of it cutting all the material in front it was putting strain on the x axis belt and in return jumped a tooth at some point in the toolpath. I cut down the feedrate from 60ipm to 40ipm and the quality of the cut increased TREMENDOUSLY.
It's pretty conservative but for CE grade phenolics I recommend:
3 flute coated carbide endmill
40-50IPM (1016-1270mmPM)
.008" depth per pass (.203mm)
#2 on Dewalt DW611
