Just started assembling my SO3, and I have a question about the eccentric nuts and the v-wheels on the Y-axis. It says the gantry should move freely, without binding, grinding, etc. When I tighten down the eccentric nuts at the bottom of the Y rails, it gets pretty tight. I would say it moves "smoothly", but definitely not "freely". Should I be able to tap it an watch it slide to the other end? Or is the resistance a good thing? Holding off on the belts until I hear from you guys.
How tight should v-wheels be?
Re: How tight should v-wheels be?
There should be some resistance / friction, but not much:
http://www.shapeoko.com/wiki/index.php/ ... g_V-wheels
Bart, the creator of Makerslide, gave the following advice on tightening the v-wheels: loosen the eccentric spacer until the v-wheel does not rotate when the carriage is moving and then tighten just (and no more!) until the v-wheel rotates when moving the carriage. Overtightening will lead to the v-wheel wearing out.
Thanks...that makes it pretty clear. There's a lot more fine tuning than you'd gather from the "install vs. engaged" diagrams.
Probably it would be clearer still if that last was reversed to, ``tighten until rotating the V-wheel begins to move the carriage'' or something along those lines.
