Skewed X axis
Sorwrith
Skewed X axis
Post by Sorwrith » Thu Jan 21, 2016 7:06 am
So I currently have an issue with my machine. The bed of the machine is straight, maybe not as square as I would like but seems square enough. Problem is, the X-axis is skewed on one side by about a millimeter or two. If I bring the gantry completely to the front the left side plate will make contact to the steel plate that the Y-axis extrusion is bolted on to, but the right side is about 1 or 2 millimeters off. Would shimming the back 2 bolts on the X-axis extrusion on the left side fix the issue or is there something fundamentally wrong with my plates or extrusion?
Shapeoko 3 #0085
Re: Skewed X axis
Post by WillAdams » Thu Jan 21, 2016 12:06 pm
Yes, shimming the parts is one way to fix this.
Before that, instead (after squaring the frame) try:
- loosen the X-axis belt
- loosen the gantry end plate bolts
- clamp the end plates against the front panel
- measure the location of the X-axis extrusion relative to the front panel, carefully square and plumb as necessary
- gradually tighten the bolts, checking and adjusting as you go.
