shapeoko 2 1M x1M help
op117
Post by op117 » Mon Feb 08, 2016 7:38 pm
after up grading my 250mmx250mm shapeoko to a 1Mx1M my Y axis is skipping at high feeds.
the way it skips is like it walk left / right thin loses it place on a job when i run a lower feed in the same job.
whats the best way to fix this?
the belts are tight.
skips after 30 in/min
could not find right threads for the old 2 any more or help threads
Re: shapeoko 2 1M x1M help
Post by WillAdams » Mon Feb 08, 2016 7:47 pm
You may need to reduce feed rates and/or acceleration.
For the larger machines, I believe that 9mm wide belts are a big help.
op117
Post by op117 » Mon Feb 08, 2016 7:58 pm
what causes the belts to jump not enough tooth's catching or are the belts flexing?
Post by WillAdams » Mon Feb 08, 2016 8:16 pm
The SO2 doesn't have as much belt engagement as the SO3, and the longer belt means that belt tension will vary more at the center.
More information at: http://www.shapeoko.com/wiki/index.php/ ... nd_Pulleys
op117
Post by op117 » Thu May 05, 2016 1:14 am
up graded to 9mm belts and no luck here is a video of it
https://www.youtube.com/watch?v=OcXiIyY ... e=youtu.be
the belts are right and i adjusted the motor power a little thinking it was that but no luck
any ideas?
also it done this before the 9mm upgrade
bharbour
Post by bharbour » Thu May 05, 2016 1:34 pm
If it's the Y axis...what I'm taking to mean the axis with the two Nema17's driving it, then you might have a mismatch in belt tension between the two. Park your Y axis somewhere in the middle of the rail and pluck each belt like a string. Listen to see if they're basically the same pitch. If not, adjust until they are. Just my humble opinion...
Post by WillAdams » Thu May 05, 2016 2:32 pm
What we have on the wiki is at:
http://www.shapeoko.com/wiki/index.php/ ... he_Machine
http://www.shapeoko.com/wiki/index.php/ ... leshooting
If the information and techniques there don't help, contact tech support at the place you bought your machine from.
William
