Anyone do metal V-wheel rollers?
Gamble
Post by Gamble » Fri Feb 19, 2016 7:54 am
I have less than 3 hours of cut time on my machine as I'm still learning and today a V-wheelroller on the X axis plate shit the bed. Blew a chunk off the outside of it.
I saw these while browsing
https://www.inventables.com/technologie ... l-5mm-bore
However I rather give my money to the guys at SO
CNC Plasma Table
Tig, Mig Welders
Shapeoko3
Re: Anyone do metal V-wheel rollers?
Post by WillAdams » Fri Feb 19, 2016 11:50 am
The metal V-wheels are only suited for use w/ steel rails. The idea was that they would work w/ hard anodized aluminum but that’s not been the case.
One interesting observation though is that since the SO3 has a V along only one side, it should be possible to upgrade it to metal wheels by:
- turning all the extrusion around
- mounting a compatible steel V-rail profile
- getting wheels of a suitable diameter
It’s quite rare for the wheels to fail though, and usually it’s been a moulding flaw --- contact support@carbide3d.com about this and they’ll set it right, and I doubt it’ll happen (to you) again.
We looked at material alternatives to Delrin a while back, and for something made to replace a feather quill, it’s surprisingly well-suited to this.
Post by cvoinescu » Fri Feb 19, 2016 2:14 pm
Those steel V-groove bearings are excellent. (Well, I don't know about the ones from Inventables, but I'm very, very happy with the ones I sourced.) I use them in a machine that faces roughly cut MakerSlide, shaving 0.5 mm off in one pass over the entire height of the profile, with a 1/4" endmill (1" length of cut). The wheels are nice and rigid. (MakerSlide is 6005A-T6 and varies between about 5 mm and more than 12 mm of vertical contact between the endmill and the stock. I remove between 0.3 and 0.7 mm in one pass -- conventional cut.)
However, after only 100 cycles, the anodic layer on the MakerSlide is mostly gone. The machine still works great, but, if you use those steel V-groove bearings, the rails must be treated as consumables. I think I'll get at least 2000 cycles before I need to replace the rails. I would be reluctant to do that with a Shapeoko 3, but MakerSlide is easily available, so I have no qualms about that.
I might try hard anodizing, if I can find a local shop do do a couple of pieces for not a lot of money. I have some hardcoat OpenRail I can try, too, if I have too much time on my hands. But yes, steel rail is the way to go.
bharbour
Post by bharbour » Fri Feb 19, 2016 3:09 pm
I also thought about turning the makerslide around and attaching a steel v-rail...or even something that I could use with skate bearings. When I read other post about the plastic v wheels failing, I promptly purchased a couple of spares!
WillAdams wrote:The metal V-wheels are only suited for use w/ steel rails. The idea was that they would work w/ hard anodized aluminum but that’s not been the case.
AnonymousPerson
Post by AnonymousPerson » Fri Feb 19, 2016 3:34 pm
cvoinescu wrote:I might try hard anodizing, if I can find a local shop do do a couple of pieces for not a lot of money. I have some hardcoat OpenRail I can try, too, if I have too much time on my hands. But yes, steel rail is the way to go.
There's a decent amount of info on the Net for doing standard aluminium anodizing, but there doesn't seem to be good info for doing hard anodizing. eg voltage & current settings, recommended bath/solution, etc
Don't suppose you've come across the info? :)
Post by cvoinescu » Fri Feb 19, 2016 4:01 pm
You need a refrigerated tank, just above freezing. That's enough to convince me to leave it to the professionals. :)
Post by twforeman » Fri Feb 19, 2016 5:26 pm
cvoinescu wrote:You need a refrigerated tank, just above freezing. That's enough to convince me to leave it to the professionals. :)
Do it in your chest freezer?
AnonymousPerson
Post by AnonymousPerson » Sat Feb 20, 2016 3:23 pm
Where did you find the info? If you can point me at it, I might give it a shot. :)
AnonymousPerson
Post by AnonymousPerson » Mon Feb 22, 2016 6:05 am
Went looking earlier, and the closest to actually useful info for hard anodizing is here:
http://www.caswellplating.com/anodizing ... ystem.html
It has temperature range, rough info on bath composition, and voltage/current requirements. Which every other place seems to skip over. :evil:
There are BS / MIL (etc) standards for hard anodizing (called Type III apparently), but they don't seem to be publicly available. Needs to be purchased from the appropriate standards body (etc).
Post by cvoinescu » Mon Feb 22, 2016 2:46 pm
I didn't have more information than that, sorry. Type III is the US name, yes.
