Spindle wont go up anymore at beginning of job
jfboyd
Post by jfboyd » Tue Apr 19, 2016 2:29 am
Any idea why my spindle wont go up at the beginning of a job to clear the stock surface? It just go straight from zero to beginning of the job. If surface is not 100% levelled, it will scratch it.
I just changed my board for the new one to fix the disconnect issue. I thought it would fix this too, but it's still doing it. Im creating my Gcode with Create.
Thanks for your help!
B NEGATIVE
Re: Spindle wont go up anymore at beginning of job
Post by B NEGATIVE » Tue Apr 19, 2016 5:54 pm
Zero the Z and jog it up a few mm before running the job,it still knows where zero is. Unless you define a retract height and code for it,it will just run from where you left it.
_Us3rnam3
Post by _Us3rnam3 » Tue Jun 21, 2016 7:54 pm
I had the same issue. It would drag the end mill through the stock.
The retract height has been zeroed out. Just specify a retract height in Motion and/or Create to rectify.
