Loose Z axis mounting plate - cant seem to tighten
kristenanne77
Post by kristenanne77 » Tue Jun 07, 2016 9:21 pm
Havent used my machine in a few weeks.
After just setting it up I noticed the Z axis mounting plate was really loose.
Ii appears like all the screws are tight , so why is it so loose?
Anyone know what could be causing this?
I attached a link showing the problem.
K
http://youtu.be/HYTZ7HD4LxU
Re: Loose Z axis mounting plate - cant seem to tighten
Post by cvoinescu » Tue Jun 07, 2016 9:51 pm
The video is private.
kristenanne77
Post by kristenanne77 » Tue Jun 07, 2016 10:11 pm
Thanks. I will try to figure out how to make it public.
K
kristenanne77
Post by kristenanne77 » Tue Jun 07, 2016 10:26 pm
I uploaded again and I think its public now.Try this link for the video
https://youtu.be/JypTIw4ksyw
K
Post by cvoinescu » Tue Jun 07, 2016 11:47 pm
Your V-wheels are awfully loose. You need to adjust the eccentric nuts.
RoguePirin
Post by RoguePirin » Wed Jun 08, 2016 2:12 pm
cvoinescu wrote:Your V-wheels are awfully loose. You need to adjust the eccentric nuts.
I had this problem too. Unfortunately, turning the eccentric nuts just wouldn't tighten the v-wheels enough. Turns out that I had the 2 Z-Axis gantry-like pieces (the silver pieces that the v-wheels ride on) too far apart. Once I moved them closer together, I was able to get proper tension with the v-wheels by adjusting the eccentric nuts. Just something else to consider.
kristenanne77
Post by kristenanne77 » Wed Jun 08, 2016 3:03 pm
Yes...It was the eccentric nuts on the V wheels.
I have definitely got to get a bright shop light to look at these things in a semi dark garage!
K
461oceanblvd
Post by 461oceanblvd » Thu Jun 16, 2016 2:39 am
If the problem still isn't solved, you may have a cracked/broken V-wheel. That is a problem that I had from a cut failure and it crashing into the material while still moving.
LTEPM
Post by LTEPM » Thu Jun 16, 2016 5:13 am
You can also move the Z axis rails closer to each other if the eccentric nuts don't tighten enough and it is not a cracked wheel.
LTEPM
