Easy way to tension the Z belt
CastIrony
Post by CastIrony » Tue Jul 26, 2016 7:16 am
While rebuilding my Z axis carriage, I decided to do a better job of tensioning the Z belt, since it was always much looser than the other belts on my machine. After a bunch of pulling, lifting, fastening, and unfastening, I had a really good idea.
Just loosen the Z motor bolts, and shove a wooden door shim in between the motors from both sides:
IMG_2595 2.jpg (166.89 KiB) Viewed 4068 times
Then tighten the Z motor bolts, and remove the shims. I had to use a hammer to get them out, but you might be able to just wiggle them free.
These shims are cheap and easy to find, I think my hardware store sells a pack of a dozen for $2.
Re: Easy way to tension the Z belt
Post by WillAdams » Tue Jul 26, 2016 10:21 am
Yeah, I had to use a small pry bar on mine, and I worried about bending the motor shaft.
Added to the wiki.
Post by twforeman » Tue Jul 26, 2016 12:47 pm
This is how I tension mine too. Works a treet.
Ender 3 3D Printer
LTEPM
Post by LTEPM » Tue Jul 26, 2016 5:30 pm
I use wedges to tighten my X axis as well, leave them in place, then tension the Z axis motor the same way.
hatallica
Post by hatallica » Sun Sep 18, 2016 3:07 am
Major kudos, CastIrony! This saved me tons of grief on Friday. In the middle of running a few projects, the Z axis just gave up and barely skimmed the surface. Thankfully, I still had a few shims in my tool closet (my wife - God bless her soul - used most of them as paint stirrers).
Ten minutes later, I was back to making a pile of oak chips. Cheers!
Shapeoko3 #1153
KAScnc
Post by KAScnc » Fri Sep 30, 2016 12:30 am
Some reason my belt was already tight with the stepper in the lowest position. I had to loosen the two 15mm spacers to gain enough slack to get the belt over the top pulley. Once everything was routed correctly, I tightened those two spacers which tensioned the belt without having to raise the stepper.
CastIrony
Post by CastIrony » Fri Sep 30, 2016 4:30 pm
KAScnc wrote:Some reason my belt was already tight with the stepper in the lowest position. I had to loosen the two 15mm spacers to gain enough slack to get the belt over the top pulley. Once everything was routed correctly, I tightened those two spacers which tensioned the belt without having to raise the stepper.
Do you have the old or new style Z carriage plate? The old one was a little bit more adjustable, which might explain that.
KAScnc
Post by KAScnc » Fri Sep 30, 2016 9:39 pm
Hmm, I'll assume it was the original style. It was the spark fun edition purchased Dec 2015. I just got the upgraded (front) Z-Plate few days ago.
What I don't have is that adjustment screw on the back plate that puts tension on the z-belt pictured here.
Post by WillAdams » Fri Sep 30, 2016 10:29 pm
Pick up a stainless steel SHCS at your local hardware store.
KAScnc
Post by KAScnc » Fri Sep 30, 2016 10:43 pm
WillAdams wrote:Pick up a stainless steel SHCS at your local hardware store.
That would be sort of obvious if the plate had an adjustable slot for the bottom guide pulley and a threaded bung welded to the plate for that steel SHCS tension screw. :D
Maybe this is a Sparkfun thing?
