cvoinescu wrote:Please do not cross-post. I have deleted your nearly identical post on a two-year-old, off-topic thread.
Yes, I posted the same problem on a poll to elaborate that I voted for "Homing only" but that the homing in fact has not been succes full so far!
Excuses for violating the rules!
cvoinescu wrote:What you describe can mean that your Z homing switch appears actuated when it actually isn't, so the machine is trying to back off it, and gives up after 10 mm. Maybe you've wired it NC when it should be NO, or the other way round? Note that some boards have Schmitt triggers that may invert the state of the pins, so that you need to set the software to NO but use NC switches, or the other way round.
But if so, wouldn't the same switch trigger the Switch-Limit? I use NO switches that detect the switch closing when jogging the XY or Z-axis into the switch..
Is there a way to test this? The Stepoko board has limit-switch ledjes that do not light until actually closing a switch
===== later that day =====
I changed $23 and did some more test. The inverted homing does move the axis in the right direction, but still stops every 10mm. Repeatedly "Homing" brings the Z-axis into the switch slowly goes down a few mm and then goes all the way up again. Same for the X and Y axis so eventually the Spindle is at the Top, Right Back of the machine but with all the switches pressed in.
After that jogging one of the axis in either direction (+ or -) makes the machine slamming to the switches!!!
Code: Select all
====>> Changed $23=4 <<=========================================================
====>> homing dir invert mask:00000111 <<=======================================
___________gc_not_motion___________
___________$23=7 ___________
ok
___________gc_dwell___________
___________N0 G4P0.05 ___________
___________gc_get_offsets___________
___________$# ___________
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
___________gc_parser_state___________
___________$G ___________
[G0 G54 G17 G21 G90 G94 M0 M5 M9 T0 F0. S0.]
ok
<Idle,MPos:-420.000,-460.000,-75.000,WPos:-420.000,-460.000,-75.000,Buf:0,RX:0,Lim:000>
___________$$ ___________
$0=10 (step pulse, usec)
$3=5 (dir port invert mask:00000101)
$6=0 (probe pin invert, bool)
$10=255 (status report mask:11111111)
$11=0.020 (junction deviation, mm)
$12=0.010 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=1 (hard limits, bool)
$22=1 (homing cycle, bool)
$23=7 (homing dir invert mask:00000111) <<====
$24=100.000 (homing feed, mm/min)
$25=1000.000 (homing seek, mm/min)
$26=25 (homing debounce, msec)
$27=5.000 (homing pull-off, mm)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=40.000 (z, step/mm)
$111=5000.000 (y max rate, mm/min)
$112=5000.000 (z max rate, mm/min)
$120=400.000 (x accel, mm/sec^2)
$121=400.000 (y accel, mm/sec^2)
$122=400.000 (z accel, mm/sec^2)
$130=425.000 (x max travel, mm)
$131=465.000 (y max travel, mm)
$132=80.000 (z max travel, mm)
ok
====>> Start Homing <<==========================================================
====>> Z-axis goes up apr. 10mm then stops <<===================================
====>> Repeat Homing until Z-axis hit switch, backsoff slowly <<================
====>> and then goes all the way up again till Limit Switch closed <<===========
====>> Repeat Homing until all axis are in Limit Switch <<======================
___________gc_homing___________
___________$h ___________
<Home,MPos:-420.000,-460.000,-75.000,WPos:-420.000,-460.000,-75.000,Buf:0,RX:0,Lim:000>
ok
___________gc_wait_for_idle___________
___________N0 G4P0.005 ___________
ok
___________gc_sync___________
[TLO:0.000]
ok
ok
====>> Goto Jogging <<==========================================================
___________SET MACHINE STATE: JOGGING___________
___________gc_motion___________
___________N0G1X-415.000Y-425.000Z-51.550F1039.2 ___________
ok
==========>>> Jogging [Z-] all hell breaks lose!!! <<<==========================
==========>>> All axis hitting the limit switches to the max <<<================
<Run,MPos:-419.675,-457.800,-73.525,WPos:-419.675,-457.800,-73.525,Buf:1,RX:0,Lim:000>
<Run,MPos:-419.275,-454.975,-71.625,WPos:-419.275,-454.975,-71.625,Buf:1,RX:0,Lim:000>
<Run,MPos:-418.875,-452.100,-69.700,WPos:-418.875,-452.100,-69.700,Buf:1,RX:0,Lim:000>
<Run,MPos:-418.450,-449.225,-67.775,WPos:-418.450,-449.225,-67.775,Buf:1,RX:0,Lim:000>
<Run,MPos:-418.050,-446.375,-65.875,WPos:-418.050,-446.375,-65.875,Buf:1,RX:0,Lim:000>
<Run,MPos:-417.650,-443.500,-63.950,WPos:-417.650,-443.500,-63.950,Buf:1,RX:0,Lim:000>
<Run,MPos:-417.225,-440.650,-62.025,WPos:-417.225,-440.650,-62.025,Buf:1,RX:0,Lim:000>
<Run,MPos:-416.825,-437.800,-60.125,WPos:-416.825,-437.800,-60.125,Buf:1,RX:0,Lim:000>
<Run,MPos:-416.425,-434.950,-58.200,WPos:-416.425,-434.950,-58.200,Buf:1,RX:0,Lim:000>
<Run,MPos:-416.000,-432.075,-56.300,WPos:-416.000,-432.075,-56.300,Buf:1,RX:0,Lim:000>
<Run,MPos:-415.600,-429.200,-54.375,WPos:-415.600,-429.200,-54.375,Buf:1,RX:0,Lim:000>
<Run,MPos:-415.200,-426.350,-52.450,WPos:-415.200,-426.350,-52.450,Buf:1,RX:0,Lim:000>
<Idle,MPos:-415.000,-425.000,-51.550,WPos:-415.000,-425.000,-51.550,Buf:0,RX:0,Lim:000>
======>> pressing [Z-] again the spindle goes down a mm <<======================
___________N0G1X-415.000Y-425.000Z-52.550F600.0 ___________
ok
<Idle,MPos:-415.000,-425.000,-52.550,WPos:-415.000,-425.000,-52.550,Buf:0,RX:0,Lim:000>
___________N0G1X-414.000Y-425.000Z-52.550F600.0 ___________
ok
<Idle,MPos:-414.000,-425.000,-52.550,WPos:-414.000,-425.000,-52.550,Buf:0,RX:0,Lim:000>
___________N0G1X-413.000Y-425.000Z-52.550F600.0 ___________
ok
<Idle,MPos:-413.000,-425.000,-52.550,WPos:-413.000,-425.000,-52.550,Buf:0,RX:0,Lim:000>
ok
<Run,MPos:-414.550,-425.000,-52.550,WPos:-414.550,-425.000,-52.550,Buf:1,RX:0,Lim:000>
___________N0G1X-415.000Y-424.000Z-52.550F600.0 ___________
ok
___________N0G1X-415.000Y-423.000Z-52.550F600.0 ___________
<Run,MPos:-415.000,-423.450,-52.550,WPos:-415.000,-423.450,-52.550,Buf:1,RX:0,Lim:000>
___________N0G1X-415.000Y-422.000Z-52.550F600.0 ___________
ok
<Idle,MPos:-415.000,-422.000,-52.550,WPos:-415.000,-422.000,-52.550,Buf:0,RX:0,Lim:000>
___________N0G1X-415.000Y-421.000Z-52.550F600.0 ___________
ok
<Idle,MPos:-415.000,-421.000,-52.550,WPos:-415.000,-421.000,-52.550,Buf:0,RX:0,Lim:000>
ok
<Run,MPos:-415.000,-422.550,-52.550,WPos:-415.000,-422.550,-52.550,Buf:1,RX:0,Lim:000>
ok
<Idle,MPos:-415.000,-424.000,-52.550,WPos:-415.000,-424.000,-52.550,Buf:0,RX:0,Lim:000>
ok
So, setting $23 to 7 seems like a good idea. But how to proceed now????
But now, even if I reset the Stepoko and try to jog f.i. the X-axis, the machine seems to move all the way to the Homing position untill it hits a limit switch
Code: Select all
___________N0G1X414.000Y425.000Z52.550F600.0 ___________
ok
<Run,MPos:1.100,1.125,0.150,WPos:1.100,1.125,0.150,Buf:1,RX:0,Lim:111>
<Run,MPos:2.500,2.575,0.325,WPos:2.500,2.575,0.325,Buf:1,RX:0,Lim:111>
<Run,MPos:3.875,4.000,0.500,WPos:3.875,4.000,0.500,Buf:1,RX:0,Lim:111>
<Run,MPos:5.275,5.425,0.675,WPos:5.275,5.425,0.675,Buf:1,RX:0,Lim:111>
<Run,MPos:6.675,6.850,0.850,WPos:6.675,6.850,0.850,Buf:1,RX:0,Lim:111>
<Run,MPos:8.050,8.275,1.025,WPos:8.050,8.275,1.025,Buf:1,RX:0,Lim:111>
<Run,MPos:9.450,9.700,1.200,WPos:9.450,9.700,1.200,Buf:1,RX:0,Lim:111>
<Run,MPos:10.850,11.125,1.375,WPos:10.850,11.125,1.375,Buf:1,RX:0,Lim:111>
<Run,MPos:12.225,12.550,1.550,WPos:12.225,12.550,1.550,Buf:1,RX:0,Lim:111>
<Run,MPos:13.625,13.975,1.725,WPos:13.625,13.975,1.725,Buf:1,RX:0,Lim:111>
<Run,MPos:15.000,15.400,1.900,WPos:15.000,15.400,1.900,Buf:1,RX:0,Lim:111>
<Run,MPos:16.400,16.850,2.075,WPos:16.400,16.850,2.075,Buf:1,RX:0,Lim:111>
<Run,MPos:17.775,18.250,2.250,WPos:17.775,18.250,2.250,Buf:1,RX:0,Lim:111>
<Run,MPos:19.175,19.675,2.425,WPos:19.175,19.675,2.425,Buf:1,RX:0,Lim:111>
<Run,MPos:20.575,21.125,2.600,WPos:20.575,21.125,2.600,Buf:1,RX:0,Lim:111>
<Run,MPos:21.975,22.550,2.800,WPos:21.975,22.550,2.800,Buf:1,RX:0,Lim:111>
<Run,MPos:23.375,23.975,2.975,WPos:23.375,23.975,2.975,Buf:1,RX:0,Lim:111>
<Run,MPos:24.750,25.400,3.150,WPos:24.750,25.400,3.150,Buf:1,RX:0,Lim:111>
<Run,MPos:26.150,26.825,3.325,WPos:26.150,26.825,3.325,Buf:1,RX:0,Lim:111>
<Run,MPos:27.525,28.275,3.500,WPos:27.525,28.275,3.500,Buf:1,RX:0,Lim:111>
<Run,MPos:28.925,29.700,3.675,WPos:28.925,29.700,3.675,Buf:1,RX:0,Lim:111>
<Run,MPos:30.325,31.125,3.850,WPos:30.325,31.125,3.850,Buf:1,RX:0,Lim:111>
<Run,MPos:31.700,32.550,4.025,WPos:31.700,32.550,4.025,Buf:1,RX:0,Lim:111>
<Run,MPos:33.100,33.975,4.200,WPos:33.100,33.975,4.200,Buf:1,RX:0,Lim:111>
<Run,MPos:34.500,35.400,4.375,WPos:34.500,35.400,4.375,Buf:1,RX:0,Lim:111>
<Run,MPos:35.875,36.825,4.550,WPos:35.875,36.825,4.550,Buf:1,RX:0,Lim:111>
<Run,MPos:37.275,38.250,4.725,WPos:37.275,38.250,4.725,Buf:1,RX:0,Lim:111>
<Run,MPos:38.675,39.700,4.900,WPos:38.675,39.700,4.900,Buf:1,RX:0,Lim:111>
<Run,MPos:40.050,41.100,5.075,WPos:40.050,41.100,5.075,Buf:1,RX:0,Lim:111>
<Run,MPos:41.450,42.550,5.250,WPos:41.450,42.550,5.250,Buf:1,RX:0,Lim:111>
<Run,MPos:42.825,43.975,5.425,WPos:42.825,43.975,5.425,Buf:1,RX:0,Lim:111>
<Run,MPos:44.225,45.400,5.625,WPos:44.225,45.400,5.625,Buf:1,RX:0,Lim:111>
<Run,MPos:45.625,46.825,5.800,WPos:45.625,46.825,5.800,Buf:1,RX:0,Lim:111>
<Run,MPos:47.000,48.250,5.975,WPos:47.000,48.250,5.975,Buf:1,RX:0,Lim:111>
<Run,MPos:48.400,49.700,6.150,WPos:48.400,49.700,6.150,Buf:1,RX:0,Lim:111>
<Run,MPos:49.800,51.125,6.325,WPos:49.800,51.125,6.325,Buf:1,RX:0,Lim:111>
ALARM: Hard limit
[Reset to continue]
___________GRBL WATCHDOG EXPIRED___________
___________SET MACHINE STATE: NOTCONNECTED___________
I'm a newby and have no idea what all the log messages mean. But I do understand the "ALARM: Hard limit" message..
