I decided to try tramming half the board in the Y axis direction instead of X and the lines seem to disappear.
Some searching on here showed me that my spindle was out of alignment. The Y axis rails are all evenly spaced from the base frame to the best of my ability. The gantry is slightly out of alignment but the Z axis plate is out of alignment even more which hopefully you can tell in the pictures. If it's not obvious looking at the square then look at the plate compared to the z axis guide rails.
I loosened the bolts on the Y axis plates to try and square up the gantry but the extrusion didn't seem to be able to move. I'm not sure what how to square up the z axis plate. I didn't see anything on the wiki about how to exactly address these problems. Any help would be greatly appreciated. If I need to take any more pictures to answer any questions please let me know.
