Shapeoko 3 XL upgrade --- Some thoughts
Re: Shapeoko 3 XL upgrade --- Some thoughts
Post by WillAdams » Sun Sep 04, 2016 3:02 pm
Be sure to label the wiring leads
Post by WillAdams » Sun Sep 04, 2016 9:28 pm
Decide if you want a spacer board before assembly. If so:
- prepare the spacer board first. Suggest 23 1/4" x 39" (or 39 1/2")
- drill and countersink four holes in the spaces between the structure before assembly while the spacer board is clamped to it.
- install 4 T-nuts in the bottom of the waste board
Post by WillAdams » Sun Sep 04, 2016 10:47 pm
And if you're cutting 3 48" lengths of T-track into thirds then only 3 1/2 and 7 1/2 spacers are too wide -- get 1 1/2 as well.
Post by WillAdams » Mon Sep 05, 2016 12:50 pm
Okay, here's what I have
brown is MDF Spacer board
silver is T-track
white is PVC
Post by WillAdams » Mon Sep 05, 2016 2:55 pm
Drew up the XL/XXL wasteboard
please verify before use
http://www.shapeoko.com/wiki/index.php/ ... 099_xl.svg
Post by WillAdams » Mon Sep 05, 2016 10:24 pm
Done.
Pretty much all the tools I used (except for saw, miter box, clamps, and a few other odds and ends)
Post by WillAdams » Tue Sep 06, 2016 1:36 am
Final thought on the Y-axis drag chain -- flip the sheet metaI over, file down the center to accommodate the belt anchors and fasten it to the holes on either side of them.
Post by WillAdams » Tue Sep 06, 2016 2:27 pm
Not really helpful to cut the PVC to 16" lengths --- the stuff is cheap and lightweight, and the additional clamping surface might be helpful.
Cutting the T-track is a pain, and results in a patterning of screw holes which offends my OCD, and results in the 6 outside sections only having two holes, and wanting a third added at the back --- will have to drill that, and source a countersink which will fit in-between the tracks.
Lastly --- save the boxes! it makes for a handy way to cover the machine (fitting perfectly if you have an XL, unfortunately the electronics enclosure gets in the way, but I'm thinking I'll be able to cut a hole in one half for that, cut out the bottom, then tape / glue it to the other half and have a nice dust cover.
Post by WillAdams » Mon Sep 19, 2016 6:02 pm
Follow-up based on a reply on the Carbide 3D forums:
For the XL upgrade from an older style machine:
- re-use the original belt anchor clips for the X-axis (or drill out in-between the M3 holes so as to use the new ones)
- the electronics move to the side of the machine on the XL/XXL --- you'll need to swap around the extrusions to accommodate that.
neilferreri
Post by neilferreri » Mon Nov 07, 2016 3:35 am
Thanks for the tips!
How did you attach the PVC to the MDF wasteboard?
WillAdams wrote:Done.
