Hi all,
maybe a trivial question, but I am a beginner: What is the usual directions for the axis on my Shapeoko? E.g. is X+ a left or right on the X axis, is Y+ a forward or backwards on the Y axis and is Z+ up or down on the Z axis?
Best regards,
Reiner
How are the axis directions named?
Re: How are the axis directions named?
Not trivial at all (and a matter of some debate)
Used to be in the instructions: http://shapeoko.github.io/Docs/electronics.html
Please see the glossary anytime terms are confusing http://www.shapeoko.com/wiki/index.php/GlossaryGo For a Spin
Z-Axis --- (Counterclockwise) Note that when testing, the Z-axis should turn for a longer duration than the other axes since the screw requires more revolutions to move a given distance than the belts used on the X- and Y-axes. With the standard drive (M8 on Z, 20-tooth GT2 on X and Y), for the same distance travelled, the Z motor turns 8 times more than the X and Y motors. Positive moves are up, negative are down.
Another Spin
X-Axis --- (Counterclockwise) the X- and Y-axis should move for the same duration for a given degree of movement. Positive moves will be to the right, negative towards the left.
And a Final Spin
Y-Axis --- (Both Clockwise and Counterclockwise) make certain that the two motors for the Y-axis are rotating in opposite directions --- the one which is for the right side of the gantry should turn clockwise, the one for the left should turn counter-clockwise. Positive moves will be away from the front of the machine, negative moves towards the front.
I thought that this is something with a potential for religious discussions
I've seen those on the same topic when it comes to 3D printers.
Thanks for explaining the Shapeoko notation, @WillAdams!
Thankfully, no. It's pretty much agreed that the axes match what we usually see in CAD programs, which is X to the right and Y to the top as viewed from the top, with Z pointing upwards. It's the same for 3D printers.reibuehl wrote:I thought that this is something with a potential for religious discussions
What is the desired position for homing then? My current setup homes at (max X, max Y, max Z) in that coordinate system. Is this okay or should I use the $23 bitmask to set it to (min X, min Y, max Z)? I have limit switches on both ends of the X and Y axis...
Top right is traditional 'cause it's safest --- use a work coordinate system to map from that.
