I noted that other(s) have had the issue of the z axis slipping back under the tension of the springs. In my case,
the Z axis slammed back so hard to "0" that it destroyed the limit switch. Machine is shapeoko 3 only about ~1 month old
Where does one find spare replacement parts? Is there a digikey part number for the swithch?
I can just resolder if I can find the right one that fits the hole pattern etc.
Help!
Need new limit switch- Z axis lets go and destroyed it. Part
Re: Need new limit switch- Z axis lets go and destroyed it.
Yes, the one Will referenced is the correct part number.
Note that this is the same answer that was given to you in your other thread (Z axis "jumps" up at a certain point) where you asked the same question.
Also, FWIW, this is on the wiki as well: http://www.shapeoko.com/wiki/index.php/ ... Shapeoko_3
