Hi Guys,
I'm new and just completed the Shapeoko 3 install. Excellent instructions (except for having to google for limit switch install and missing the part about the router mount causing me to reverse some stuff).
Now that it's all together I get cutter not found. I have a known good Power Supply, green light on it. I took the back off and pressed the micro switch on the board thinking that's a reset. I was just trying to connect with Motion to home the limit switches.
Any ideas what to do when this happens?
Thanks,
Rick
Cutter Not found
Re: Cutter Not found
List of things to try / check here: http://docs.carbide3d.com/article/56-ca ... ine-or-jog --- hopefully re-flashing won't be needed.
After your last email I confirm that definitely no sound, or click when plugged in, and the gantry still moves easily. Since I have a green light on the power brick, looks like I'll be tracing it out with a multi-meter tonight. I took the back off last night and no lights on the Arduino either with the PS plugged in, or just the USB. I'm assuming there "are" lights on it I should be seeing?
Yes, apparently with the new boards the lights only happen, and the Arduino only fully works, when external power is applied.
