my07ultra wrote:I'm using a S3 XXL when I try to cut a circle it doesn't come out concentric. Any suggestions? I've tightened belts, rollers and calibrated my servos... I'm at a loss for what else it can be. Cut it at 70% federate too, but nothing seems to help. Thanks in advance.
https://www.shapeoko.com/wiki/index.php/MaterialsThe perfect cutting is not too slow, not too fast, not too shallow and not too deep. http://www.shapeoko.com/forum/memberlis ... file&u=760
I found both Y axis pulleys loose, also getting some chatter from one of the Y axis drive units... not sure what it's from, but I'm sure it's not helping anything.WillAdams wrote:When cutting, there are a number of things which influence how the machine cuts:
- belt tension --- this is tricky to get right at first: https://www.shapeoko.com/wiki/index.php ... ko_3#Belts
- pulley set screws --- http://docs.carbide3d.com/article/169-s ... set-screws
- speeds and feeds --- http://carbide3d.com/shapeoko/feedandspeed/ (and esp. plunge rate and depth of cut)
- climb vs. conventional cutting --- https://www.shapeoko.com/wiki/index.php ... al_Milling (esp. in combination w/ a roughing clearance and finishing pass)
