Joggig Z axis in the negative direction after sucessful homi
gcollector2002
Post by gcollector2002 » Sat Jan 27, 2018 1:52 am
Hello
Homing cycle works fine and leaes the machine at -5, -5 and -5
I can jog the work tabe in the x and y axis, but the z axis will only jog to -100 and stop
I can re-jog z positive, but will stop again when I jog z negative at z = -100
$0=10 (step pulse, usec)
$3=6 (dir port invert mask:00000110)
$6=0 (probe pin invert, bool)
$10=255 (status report mask:11111111)
$11=0.020 (junction deviation, mm)
$12=0.010 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=1 (soft limits, bool)
$21=1 (hard limits, bool)
$22=1 (homing cycle, bool)
$24=100.000 (homing feed, mm/min)
$25=1000.000 (homing seek, mm/min)
$26=25 (homing debounce, msec)
$27=5.000 (homing pull-off, mm)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=125.000 (z, step/mm)
$110=5000.000 (x max rate, mm/min)
$111=5000.000 (y max rate, mm/min)
$112=5000.000 (z max rate, mm/min)
$120=400.000 (x accel, mm/sec^2)
$121=400.000 (y accel, mm/sec^2)
$122=400.000 (z accel, mm/sec^2)
$130=425.000 (x max travel, mm)
$131=465.000 (y max travel, mm)
$132=1000.000 (z max travel, mm)
Thanks in advance for help
