Hi! After much back and forth, I finally pulled the trigger and my Shapeoko XL shows up tomorrow! I've spent the last couple days getting up to speed on the software and Im not looking at the best way to create a threaded table out of the MDF wasteboard. Most of the build I see seem to show using threaded inserts into the top of the table. This seems wrong to me and with any amount of pressure something that will pop right out. It seems to me the best way to do this with a tapered insert would be to do so from the back so that when you're tightening the clamp you're pull against the board, not just against the inserts threads. The Shapeoko build seems to indicate an install like this...
http://docs.carbide3d.com/tutorials/pro ... s-required
But I cant say for sure since the pictures dont show it fully and the wording isnt as clear as I'd like. Winston Moy's build (and many others) show them going into the top...
http://community.carbide3d.com/t/xl-and ... ps/4014/30
Im trying to sort out which inserts have the internal threads going in which direction since if I came in from the back I'd probably want the threads to be inverse.
Am I missing something big here? Thanks!
Threaded Table creation
Re: Threaded Table creation
Your over thinking!!jlangemak wrote:... if I came in from the back I'd probably want the threads to be inverse.
Threads are the same if the insert goes in front or back. Do you have to put a nut on a bolt in a specific direction???
ha. Yeah. I was over thinking that piece. Got to wound up in thinking about it I guess.
So what about the side you put screw them in from. Am I overthinking that too? It just seems like having them going in on the top would make it less secure.
I would agree that T-nuts from the back side make more sense.
I'm going aluminum table on mine...but I guess on an XL that might be quite a $$$$$ chunk of aluminum.
