Notice along the top you can see a slight waver in the edge line. Noticing this, I thought perhaps it was being caused by some dust or debris on the rail or in the v-Wheel. So today I took the whole carriage off and cleaned all of the vwheels with a tooth brush and ensured the rail looked fine. Put it back together and ran some test cuts. In the image below you can se the results.
Whats interesting to me is that when I measure this - the imperfections in the line are ~70mm apart. When I measure a vWheels circumference, I come out at around 65mm. Is it possible that I have a deformed vWheel that's pushing the carriage out of square briefly? Any other ideas what could be causing this?
