XXL Homing on z axis issue
cvezina
Post by cvezina » Wed Jul 18, 2018 10:00 pm
I have just finished build my Shapeoko 3 XXL. I am trying to jog but first I need to initialize the machine. Normally, the homing sequence is launched. The problem is that I am getting an error where it stated that Z switch has not been detected. Looking at the Z axis I found that it is moving down instead of moving up to hit the switch. After searching the forums, many people are saying that I probably mounted the Z axis the wrong way. I have double check and it seems to be ok. Included is a picture of my Z axis. So, any help would be great.
Thanks.
Re: XXL Homing on z axis issue
Post by WillAdams » Thu Jul 19, 2018 11:29 am
That seems correct.
The other possibilities are wiring and Grbl settings.
Please try re-sending the defaults, if you're using CM4: http://docs.carbide3d.com/support/carbi ... -motion-v4
We have a page on direction correction at: https://www.shapeoko.com/wiki/index.php ... Correction which notes the wiring aspect.
If this doesn't help, let us know at support@carbide3d.com and we'll do our best to help you get this sorted out.
cvezina
Post by cvezina » Thu Jul 19, 2018 4:41 pm
I think I found the problem. The Z switch was always on even if not in contact with the plate (see picture). When touching the switch with my finger, I found it was loosely compared to the other switches. After several push with my finger, the mechanism was fixed and the blue light turned off. I am going to test again the homing sequence later today.
After testing later today, I confirm that the problem is solved.
