And.... success! It turns out that the CDC-ACM module source code is included in the source code tree for the Pine64 Ubuntu kernel; the community member distributing images just didn't have it configured in the build. I downloaded the source code he posted, configured the CDC-ACM module to be compiled as an external kernel module, and rebuilt the kernel and modules. Once that was done, I took the cdc-acm.ko module and installed it in the original distributed kernel. I now have CDC-ACM support on the Pine64 in Ubuntu.
I launched bCNC and it successfully found the SO3 serial port. After connecting to it, I loaded the SO3 Hello World gcode and ran it several inches above the wasteboard. It ran through the entire logo without any issues.
I still can't get the HDMI video out to work over an HDMI-DVI cable, so I will look around for a used monitor with an HDMI input. All in all, I am pleased.
Workshop computer for $15
Re: Workshop computer for $15
For anyone interested in this Pine64 board for a CAM computer, the standard Ubuntu image has been updated to include the CDC-ACM module by default. So, the base Ubuntu image now includes everything needed to communicate with the Shapeoko 3. I am not sure if every linux-based controller software will work on it as is, but bCNC definitely does.
How did you go with getting your PINE talking to your SO3? My board arrived the other day, but I haven't done anything with it yet.RoguePirin wrote: If you accept the fact that this is a DIY hobby/development board, and not a commercial board ready to use off the shelf, then you expect to have to get your hands dirty and deal with a steep learning curve (kind of like the SO3). I am getting to know more about Linux/Ubuntu than I ever thought I would (kernel command lines?). But it is interesting (and sometimes frustrating).
If you want to use the board as a media center PC, or run some fancy 4K movie kiosk, the board is definitely not there yet. If all you want is a simple GUI interface to bCNC to send text GCode over the USB port, this board rocks in its current state! Now, if I could just get CDC-ACM enabled in the kernel, I could actually talk to the SO3.
Everything works great!ijv wrote:How did you go with getting your PINE talking to your SO3? My board arrived the other day, but I haven't done anything with it yet.
The only caveat that you need to be aware of is that the CarbideMotion board is a CDC device, meaning that it wants to use serial port protocols over the USB port. If you go with a Unix variant, then you need to have support for CDC in the kernel. I went with the Ubuntu build provided by user Longsleep, and he now has CDC-ACM support added as a kernel module. I installed the xubuntu-desktop and I like it. Note that I have the 2GB board; not sure which version you have and what the minimum memory should be?
Since the Pine64 only has 2 USB ports, I got a Logitech keyboard/mouse combo that uses the Unifying Receiver, which allows me to connect both the wireless mouse and wireless keyboard into one USB port. I plug the SO3 into the other USB port.
I have successfully run the Hello World gcode with a marker, and I have used this setup to drill all the holes in my waste board for my t-nuts for hold downs. I have not tried a huge project with over 100,000 lines of gcode, but I feel very confident that this little board can handle it.
Lastly, I don't have the USB disconnect issue that some have reported, even when I use a vacuum at the same time. I did ground my router before using the Pine64. Since I never really tried it with a desktop or laptop, and I grounded the router, I can't say if the Pine64 is any better for preventing a USB disconnect.
Cool, does the Ubuntu build support the LXDE desktop?
Sorry, I don't know. I stopped following the development once I got mine working.
I am a regular user of Kickstar. Working well so far me for long time.
