I am running an eShapeoko kit to create large photographic scans. While doing this, I listen to the radio. But there is quite a lot of interference and noise on the radio while the Arduino is switched on.
The electronic kit is three NEMA 17 stepper motors, three drivers, a laptop power supply, an Arduino Uno and a GAUPS shield all joined using CAT5 cable,
so no Z movement or spindle. To drive the camera, there are two USB power supplies for the camera and a cheap PSB pair of relays to control the shutter, and a couple of Ikea LED lamps.
I have included no shielding or suppressors.
Can you suggest a process to reduce the noise?
Thank you.
Radio noise
Jump to
- General Discussion
- ↳ Discussion
- ↳ For Sale
- ↳ Lounge
- Get Help!
- ↳ Shapeoko 3 Assembly
- ↳ Assembly
- ↳ Software - CAD, CAM, Workflow Help
- ↳ CAD Help
- ↳ CAM Help
- ↳ Electronics
- ↳ GRBL
- ↳ LinuxCNC
- ↳ Mach3
- ↳ tinyG
- ↳ Netduino
- ↳ PCB Fabrication
- ↳ MakerCAM
- ↳ TB6560 Driver Board Help
- ↳ Geckodrive
- ↳ Computing Hardware
- Spindles, Cutters, Etchers
- ↳ Trim Routers
- ↳ Mini Spindles - Purchased
- ↳ DIY Spindles
- ↳ Rotary Tools (like dremel)
- ↳ Other - (etchers, drag knifes, lasers)
- ↳ Pick and Place!
- ↳ Tooling & Fixtures
- Design Ideas
- Member Projects
- Build Logs
- 3D Printing
- Website
- ↳ Site Suggestions
- ↳ Site Problems
