y-axis whine
seigenblues
y-axis whine
Post by seigenblues » Mon Dec 03, 2012 6:58 am
Hey all, would appreciate a bit of help.
Just got things up and running, X-axis works, z-axis electrically is fine but the coupler doesn't turn the threaded rod, but no worries there
Problem is the y-axis just makes a little whine; light on the grblshield is on a bit longer than when running the same command on the x-axis. It doesn't seem to even be trying to move. Any ideas?
I can put up a vid tomorrow, but curious if that sounds familiar to anyone.
thanks much!
-andrew
Batch 4 Shapeoko #837, dual y & dw660
Shapeoko2, TinyG w/ dw660, NEMA23 XY.
xenoputtss
Re: y-axis whine
Post by xenoputtss » Mon Dec 03, 2012 6:06 pm
Tension of the belts, vwheels? belt should be snug, vwheels should be just tight enough to hold the arms to the makerslide.
You can adjust the tension of the VWheels with the excentric nuts that you installed. (if the belts are not attached, the gantry system should roll about with very little pressure, and roll smoothly in both the x and y direction).
Another thing could be perhaps the config for you motor isn't setup correctly, or that you have wires crossed.
seigenblues
Re: y-axis whine
Post by seigenblues » Tue Dec 04, 2012 2:10 am
Yep, one of the stepper pairs was crossed. I ran new wires and now all is good & happy, just have some major z-axis wobble.
Thanks for the help!
