Stepper Motor Wires
AtomSoft
Stepper Motor Wires
Post by AtomSoft » Sun Apr 22, 2012 11:57 am
How would you extend the wiring of the stepper motors? I was thinking small wire nuts ... any other suggestions ?
Blog / Store
Live to Love, Not to Hate.
You're not a failure because you don't make it, you're a success because you tried.
Do you like the help i give? Think i deserve a tip? DONATE
MLange
Re: Stepper Motor Wires
Post by MLange » Sun Apr 22, 2012 2:05 pm
Could splice the two wires together (stepper's and the extension), and then wrap it in heat-shrink. Check out the section on this page about Butt Soldering.
Shapeoko #280 (Inventables Batch #1)
AtomSoft
Post by AtomSoft » Sun Apr 22, 2012 2:40 pm
"Butt/Barrel Crimp Connectors" seems cleaner.
Blog / Store
sandro
Post by sandro » Sun Apr 22, 2012 5:38 pm
AtomSoft wrote:Thanks!
I wouldn't use Crimp connectors or wire nuts anywhere wire is subjected to motion (they are fine where wires are static).
Since the CNC introduces vibration, dust, and flex into the mix, I'd opt for heat-shrinked, soldered, Western Union Splices.
Check out: http://blog.makezine.com/2012/02/28/how ... standards/
AtomSoft
Post by AtomSoft » Sun Apr 22, 2012 5:46 pm
sandro wrote: I wouldn't use Crimp connectors or wire nuts anywhere wire is subjected to motion (they are fine where wires are static).
Thanks! I learned that method in high school :) long time ago... (went to Grady in NY)
Um... i guess that and some heat shrink will do :)
Blog / Store
