Source for tiny heatsinks for Pololu drivers?
ThatOtherGuy435
Post by ThatOtherGuy435 » Sun Mar 17, 2013 1:36 pm
Does anyone have a handy source for heat sinks small enough to fit on the Pololu boards? Digikey and Mouser don't seem to carry anything that small, and I'd like to see about getting a few spares to keep on hand for my 'backup' driver boards.
ShapeOko1 #??? - 1000mm Dual-drive Y, Double X, S2 gantry motor plates, ACME Z-Axis.
levlandau2
Re: Source for tiny heatsinks for Pololu drivers?
Post by levlandau2 » Sun Mar 17, 2013 2:07 pm
See this thread. Amazon and Newegg have them. They work pretty good, I think ideally I would attach all 4 drivers to a big copper CPU heatsink with a fan. That may be harder to work with though.
ThatOtherGuy435
Post by ThatOtherGuy435 » Sun Mar 17, 2013 3:51 pm
With that to put me on the right track, http://www.amazon.com/Cosmos-Aluminum-C ... 007XACV8O/ also appear to be the right size. Unfortunately I only found these after ordering the more expensive Enzotech ones! Oops.
Will Winder
Post by Will Winder » Sun Mar 17, 2013 3:59 pm
I superglued small chunks of aluminum to the polulu chips, then used heatsinks that would have been slightly too large. It has been working fine so far.
Metroid
Post by Metroid » Sun Mar 17, 2013 4:17 pm
http://www.aquatuning.nl/index.php/cPath/24_289
Here you can find more than one type of cooler.
Gr. Rob
eShapeOko #92, 4x Stepper Shield, All in One GRBL
The Wings
ejs
Post by ejs » Tue Mar 19, 2013 7:19 pm
ThatOtherGuy435 wrote:Does anyone have a handy source for heat sinks small enough to fit on the Pololu boards? ...
I carry the shorter aluminum version.
