Nema 17 motor for HobbyCNC?
jland
Re: Nema 17 motor for HobbyCNC?
Post by jland » Wed Nov 20, 2013 9:07 am
Tom Smith wrote:
jland wrote:I ordered some of these 92 oz-in Nema 17s from Stepper-Online directly here. I made the order of stepper motors and power supplies on Friday and got them today (Monday) shipped with DHL. Everything was very well packed. Unfortunately, it won't be until next year when my Shapeoko 2 kit arrives that I'll be able to test them!
I HIGHLY recommend that you start out by choosing, and obtaining, an Arduino and the control board you plan on using, and a power supply so that you can get used to using the software->control chain even before the mechanicals are assembled. I assume you are sourcing the electronics yourself, given how you are stepper shopping :)
Pre-build activities include:
  1. Flashing Arduino with GRBL
  2. Connecting Arduino with Control board (gShield, tiny G, etc)
  3. Hooking up power to control board
  4. Connecting motors to control
  5. Manually jogging motors from your pc, using raw GCode, or a control program such as Universal GCode Sender
  6. Drawing a shape, converting to GCode, and sending GCode to Arduino using the software above
All this stuff gets you familiar with the process so that once you put the machine together, you know that you have a handle on the control electronics, and therefore, hopefully, are able to debug issues with a good basis on the control side. Additionally, it is all documented on the wiki, so you don't need to do too much research to figure it all out :) (most current is here)
Tom
Yep, thanks... I have a Tiny G on the way and that's exactly what I'll be doing. As far as finding out how much useful torque these motors will produce, though, won't happen until my mechanical kit gets here in January. Lots of time to figure out the control aspects though!
burongyki
Post by burongyki » Fri Oct 12, 2018 10:55 am
samc99us wrote:Just wanted to update folks if you're looking for a unipolar (6 wire) NEMA 17 motor.
This is the beefiest motor I could find for a reasonable price: https://www.oyostepper.com/
https://www.oyostepper.com/category-6-b ... Motor.html
If you're in a rush (I'm not and can wait for shipping from China), then Pololu might be able to help you out: http://www.pololu.com/product/1200
beckhere1
Post by beckhere1 » Tue Jul 14, 2020 7:26 am
JoyMonkey wrote:
Tue Mar 19, 2013 3:59 pm
I have some hefty Nema 23 motors (305oz/in) that came with a HobbyCNC kit that I am going to use for the X and double Y axis. I picked up a Nema 17 from Inventables to run the Z axis. I figured the motor from Inventables would use less amps, be lighter, and be plenty powerful enough for what the Z axis needs.
Unfortunately, I didn't realize that the HobbyCNC driver boards can't run 4-wire bipolar stepper motors, watch reviews, which are exactly what the motors from Inventables seem to be.
Can anyone suggest a motor similar to the Inventables Nema 17 motor, but not bipolar?
zezid
Post by zezid » Mon Aug 17, 2020 4:09 am
