Measuring RPM?
lasershark1
Measuring RPM?
Post by lasershark1 » Tue May 01, 2012 3:55 am
I'm working with some ideas for speed controlling my intended spindle. I'm going to use a Ryobi One+ speedsaw... box rates it at 26k RPM, it's DC, runs off 18v, and I figure with a motor control module I can fine tune the speed. If I can do that from the Arduino running grbl is yet to be seen, but if not, then it gives me another fun project of building a digital speed/direction control with a second arduino.
But, that being said - does anyone know of a good trick/tip to actually measuring that speed? I want to run it at full bore and actually test it, then see what speeds I get running it at different settings with the motor module.
I've no idea how to test that :)
MLange
Re: Measuring RPM?
Post by MLange » Tue May 01, 2012 4:41 am
Take a search on eBay for "Laser Tachometer" :mrgreen:
orcinus
Re: Measuring RPM?
Post by orcinus » Tue May 01, 2012 7:38 am
Painting the shaft white on one side and using a regular, cheapo photo-diode RC tachometer works fine too.
Just be ready to multiply the values you get by 2-3 (because most of them "think" they're working with a 2-3 blade rotor) and don't use it under fluorescent lighting or you'll end up measuring the mains frequency instead ;)
You could build one yourself too, with an appropriate photo-cell and Arduino, although i'm not sure what the top speed and resolution would end up being. And build a simple closed loop regulator for your speed controller.
roberlin
Re: Measuring RPM?
Post by roberlin » Tue May 01, 2012 12:23 pm
if it is a brushless motor (seems unlikely I guess?) you can measure the rpm electrically by monitoring the pulses (say with an arduino) coming off the motor controller.
CptanPanic
Measuring RPM?
Post by CptanPanic » Tue May 01, 2012 6:31 pm
I saw on another forum where they did this with an arduino, and rpms were only read to 16000 rpm where it wrapped over to 8k.
minorthreat
Re: Measuring RPM?
Post by minorthreat » Tue May 01, 2012 6:38 pm
Here's a few cost effective ways you can do it:
Hollow shaft encoder (something like http://www.usdigital.com/products/encod ... ry/kit/e4p)
Hall effect gear tooth sensor + add a gear to count (http://parts.digikey.com/1/parts/948862 ... 101dc.html)
belt/gear connection to a shafted tach or encoder
minorthreat
Re: Measuring RPM?
Post by minorthreat » Wed May 09, 2012 3:45 am
I went with a Hamlin Hall Effect sensor http://www.hamlin.com/product-detail.cfm?productid=77 and just glued a magnet inside the locking pin hole of my ryobi 1zip.
Here's the code I use to read the rpm with and arduino, next up closing the loop around the speed.
volatile byte revs;
unsigned int rpmil;
unsigned long time0;
void setup()
  Serial.begin(9600);
  attachInterrupt(0, rpm_fun, FALLING);
  revs = 0;
  rpmil = 0;
  time0 = 0;
void loop()
  if (revs >= 5) {
    //Update RPM every 5 rev
    // calculate the revolutions per milli(second)
    rpmil = (millis() - time0)/revs;
    time0 = millis();
    revs = 0;
    Serial.print("RPM:");
    Serial.print(rpmil * 60000,DEC);
void rpm_fun()
  revs++;
