I'm completely renewing my electronic enclosure, and I would like to add an SSR (http://www.gotronic.fr/art-relais-wga5-6d25z-4115.htm) to control my Kress.
As far as I understand, wiring an SSR is like displayed on the image below (made with paint, sorry
I'm having problem now, due to my lack of knowledge in electronic. I would like to add a switch to it so I can turn the spindle on/off with the switch. How would I wire that ?
Here is the use case I see, but maybe it's too complicated :
- Spindle is off, TinyG spindle control is off, and turning the switch to On will turn the spindle on (standard),
- Spindle is on, TinyG spindle control is off, and turning the switch to Off will turn the spindle off (standard),
- Spindle is off, TinyG spindle control is on, and turning the switch to On will turn the spindle on,
- Spindle is on, TinyG spindle control is on, and turning the switch to Off will turn the spindle off (some kind of safety, beside the estop button),
I'd also like to add a led to it, to display the state of TinyG spindle status, but I think this will be simply wire on the TinyG On/Off port.
Thanks for the help.
