The Motors wont go on!!! HELP!
sweetv13
Re: The Motors wont go on!!! HELP!
Post by sweetv13 » Tue Sep 17, 2013 5:06 pm
Hello,
thnaks for the Reply, The motors are moving. but Now one question? I tell the machine "Z5" and it moves down? can someone help me it is suppose to move right??
Post by WillAdams » Tue Sep 17, 2013 5:19 pm
sweetv13
Post by sweetv13 » Tue Sep 17, 2013 9:56 pm
THANK YOU EVERYONE, its working now. But I do not know where to get the files from . the files that i have to upload to Gcode sender. where Do I find Them. I have autocad in my PC-
Post by WillAdams » Tue Sep 17, 2013 11:41 pm
sweetv13
Post by sweetv13 » Wed Sep 18, 2013 9:00 pm
HELLO
So i did the first job. worked really we,, the second job is pending, but NOW- how do I do my own job???? I have autocad in my pc and try to pass DFX file to CAMBAM and I try using the CAMBAM and send to Gcode sender and it worked but too small, how do I scale? is it enought Autocad and CAMBAM to transfer to GCODE SENDER???? what other software do I need to learn??
Post by WillAdams » Thu Sep 19, 2013 3:02 am
You can scale up in AutoCAD before exporting to CamBam. Perhaps the latter has measurement controls?
Not familiar w/ either program you describe (I draw in FreeHand, export to .pdf, import to Inkscape, export to SVG, then use MakerCAM), but they should work for the CAD and CAM steps:
- AutoCAD --- drawing / design --- http://www.shapeoko.com/wiki/index.php/CAD
- CAMbam --- creation of G-code --- http://www.shapeoko.com/wiki/index.php/CAM
bjbsquared
Post by bjbsquared » Thu Sep 19, 2013 10:06 am
Here is my current toolchain. It works in linux or windows.
Draft Sight (AutoCAD) -> myDesign.dxf -> CAMBam -> myDesignedCAM.nc -> GCodeSender -> GRBL controller
Maker sure that AutoCAD, CAMBam and GRBL controller are set to the same units of either mm or inches.
sweetv13
Post by sweetv13 » Thu Sep 19, 2013 1:04 pm
Thank you all. Ill try the cad and cambam today afternoon. Just one more question : Do I have to give the deep i want in axis Z ib the cambam?? I assume that is. I still hacent seeb the cambam link you post me. Maybe i can find the answer there. Thanks alot. Im almost there!
Post by WillAdams » Thu Sep 19, 2013 1:21 pm
sweetv13 wrote:Do I have to give the deep i want in axis Z ib the cambam?? I assume that is.
You assume correctly.
Using AutoCAD or some other 2D drawing or drafting program allows one to use a CAM program to extend it into what's known as 2.5D by indicating the depth to which one should cut at a given drill point, path or pocket --- one can do material removal along one side of the material w/o re-positioning it or making use of a 4th or 5th axis.
I sort of touch on that in my InkScape / MakerCAM tutorial on the wiki (which needs to be re-written --- if you have suggestions on that please edit away or comment on the Discussion page).
William
(P.S. - Your English is much better than my non-existent Spanish, high-school French, or Korean, but I thought you'd find it useful if I pointed out that what I quoted above would normally be something more like, ``Do I have to indicate the depth I want along the Z-axis in CamBam? I assume that it is.'')
Post by cvoinescu » Thu Sep 19, 2013 6:26 pm
WillAdams wrote:(P.S. - Your English is much better than my non-existent Spanish, high-school French, or Korean, but I thought you'd find it useful if I pointed out that what I quoted above would normally be something more like, ``Do I have to indicate the depth I want along the Z-axis in CamBam? I assume that it is.'')
Actually, that would be "I assume that I do", to be not only pedantic, but also correct.
