http://www.kickstarter.com/projects/log ... on-control
- 32-bit ARM processor running at 100MHz
- Plays gcode from uSD card (accessible as a mass-storage USB device) or native USB serial port
- Native USB interface with mass-storage and serial ports
- Play gcode or reconfigure from the uSD drive, or live over serial
- Interactive serial shell for gcode playback and configuration
- GRBL-derived, syntax compatible (while removing some of GRBL's limitations, such as the line length limit)
- Supports up to 5 axis, plus many peripheral controls (hot ends, thermometers, SSDs, fans, etc)
- Open source, open hardware
Eagle-eyed viewers will be able to pick out a Shapeoko in the video. To be honest I haven't worked much on my setup in a while, so it doesn't make for a particularly impressive show, but it drives well.
