digitizer probe on grbl
turtle13
Post by turtle13 » Wed Oct 16, 2013 3:46 pm
I am new to the CNC world and plan on purchasing the V2 kit as soon as instructables puts it up for sale.
I was wondering if it is possible to run a digitizer probe with the grbl board to be able to "scan" preexisting items i want to recreate or modify, without having to draw them in CAD.
I have read that you would hook up the probe like you would a home switch to zero out your end mill, however not having the hardware infront of me, i am not sure if the GRBL supports this as an option.
Or would it be smarter to just buy the mechanical kit and buy a driver and motor kit off ebay that will support mach3, and have all the bells and whistles?
tweak
Re: digitizer probe on grbl
Post by tweak » Wed Oct 16, 2013 5:32 pm
I think you need to use MACH3 for probing right now.
Seems like GRBL will support probing in the future, as you can read here: https://github.com/grbl/grbl/issues/140
ShapeOko hybrid, Dual X & Y Axis, ACME Z Axis, All NEMA 17, Kress 1050 FME-1 spindle (1.05KW), Steel V-Wheels & Hardcoat MakerSlide, Aluminum spacers, TinyG Controller, 800x550mm work area.
calica
Post by calica » Sat Oct 19, 2013 6:50 am
LinuxCNC also works well with probing.
