Raspberry Pi Wifi Remote-controlled gcode sender
pmodiano
Post by pmodiano » Sun Nov 24, 2013 3:14 am
I decided to liberate my laptop from my basement, where my loud, dusty Shapeoko resides. So I set out to build a solution that would combine my Arduino/gbrl with a WiFi-enabled, RDP-enabled Raspberry Pi to create a single solution allowing me to remote into my Shapeoko from anywhere in my house with computer or tablet. I also set out to document my project.
Part 1: http://machinesonthemind.blogspot.com/2 ... grade.html
Part 2: http://machinesonthemind.blogspot.com/2 ... de_23.html
More is to come shortly!
Paul.
Shapeoko #1075 1000mm y axis, 500mm X axis, Dual Y motors, ACME screw Z axis upgrade, DW660. http://machinesonthemind.blogspot.com/
Re: Raspberry Pi Wifi Remote-controlled gcode sender
Post by WillAdams » Sun Nov 24, 2013 3:52 am
Very cool!
I worry about remote operation though --- w/ my luck, the first time I did it, the bit would work loose, dig into the spoil board and sit there and spin until it started a fire --- you'll also add a webcam so that you can keep an eye on it?
bobt
Post by bobt » Sun Nov 24, 2013 10:37 pm
Add a Raspberry Pi camera they are only $25.00 and you can look at your machine anytime.
Bob
"What Box???" ShapeOko #397
pmodiano
Post by pmodiano » Sun Nov 24, 2013 10:49 pm
Will / Bob,
I bought the Raspberry Pi camera, with this thought in mind. The problem is it has a short ribbon cable that attaches to the raspberry pi. So if I want to go that route, I need to keep the R-Pi with camera right next to, and travelling with the tool. This means a long USB cable to the Arduino/grbl controller. Another issue is that I have no knowledge of how capturing and sending video live over wifi will impact the XRDP and the gcode sender. Maybe I need another dedicated raspberry Pi? Maybe I should use an inexpensive but completely separate monitoring system?
I need to give this video idea more thought...
Paul.
