Is acrtic silver conductive?
lasershark1
Post by lasershark1 » Thu May 31, 2012 3:46 am
I bought some heat sinks and arctic silver epoxy to attach them to my pololu drivers, and after assembling them I noticed I spilled some of the epoxy down the side of the driver chip and its spread across a few contacts. Is it conductive? Did I just ruin 2 drivers?
Will Winder
Re: Is acrtic silver conductive?
Post by Will Winder » Thu May 31, 2012 12:34 pm
I found this on the Arctic Silver web page.
http://www.arcticsilver.com/arctic_silv ... hesive.htm
Negligible Electrical Conductivity:
Arctic Silver Thermal Adhesive was formulated to conduct heat, not electricity. NOTE: Even though Arctic Silver Thermal Adhesive is specifically engineered for high electrical resistance, it should be kept away from electrical traces, pins, and leads. The cured adhesive is slightly capacitive and could potentially cause problems if it bridged two close-proximity electrical paths.
lasershark1
Post by lasershark1 » Thu May 31, 2012 12:47 pm
God dammit. I think I just blew 2 motor drivers then. Nice. Because THOSE are cheap.
JimHung
Post by JimHung » Fri Jun 01, 2012 5:43 am
Arctic Silver offer a thermal grease removal product that will help you clean off the spilled paste, or you could pick up some 99% Isopropyl Alcohol from the drugstore (don't bother with anything lower than 99%, it could well be electrically conductive itself). Using a soft cloth (preferably cotton to help avoid electrostatic discharges), dab a small amount of the alcohol and try and remove the excess from the pins, or if it's particularly heavy perhaps try a very soft bristled toothbrush (I've had luck with this in the past removing similar material from SMT pcbs).
Hope that helps,
Jim
Shapeoko #: 564
JCPhlux
Post by JCPhlux » Fri Jun 01, 2012 3:53 pm
JimHung wrote: (don't bother with anything lower than 99%, it could well be electrically conductive itself).
In the past after cleaning a part I put it in a container with rice ... uncooked :) and let it sit over night.
John R Cutburth II
Twitter @JohnCutburth
JimHung
Post by JimHung » Fri Jun 01, 2012 6:50 pm
Definitely a good idea, you want to make sure the board is totally dry and has no remaining short circuits before powering it up! :lol:
Jim
Shapeoko #: 564
